Why the rust?
#1806530
04/18/15 10:52 PM
04/18/15 10:52 PM
Posts: 1,377 Tennessee
WyleECoyote
Tennessee
So I picked up my engine from Hensley Performance last September. Winter was busy and I didn't get to the garage much, and now I see this?!!!
1. Bolt rust. Understandable, they're iron. What can I use that won't rust - or should I clean these and protect them, with clear?
2. Intake manifold - rust / discoloration. I thought these things were aluminum and would oxidize - but not discolor like this? What is going on?
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Why the rust?
[Re: 135sohc]
#1806607
04/19/15 12:23 AM
04/19/15 12:23 AM
WyleECoyote
Tennessee
Surface contamination from what? Its been untouched since new? Mostly....
Re: Why the rust?
[Re: WyleECoyote]
#1806608
04/19/15 12:26 AM
04/19/15 12:26 AM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
Mine did the same thing. Not sure what happened. Even the painted power steering box is rusting.
Re: Why the rust?
[Re: WyleECoyote]
#1806616
04/19/15 12:34 AM
04/19/15 12:34 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Temporary fix, coat with WD 40. Rub a bit of oil on them. Permanent, replace with stainless.
Re: Why the rust?
[Re: WyleECoyote]
#1806640
04/19/15 01:17 AM
04/19/15 01:17 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
It's called rust, caused by humidity [ moisture ] in your garage. If you had a climate control system in your garage you wouldn't have that problem.
Re: Why the rust?
[Re: rowin4]
#1806764
04/19/15 10:40 AM
04/19/15 10:40 AM
Posts: 1,499 Slidell, LA
Plum440
Slidell, LA
It's called rust, caused by humidity [ moisture ] in your garage. If you had a climate control system in your garage you wouldn't have that problem. What he said.
70 Challenger, 440, 4-speed, pLuM cRaZy 71 VW Super Beetle Convertible, Lemon Yellow A couple of Jeeps…
Re: Why the rust?
[Re: rowin4]
#1806794
04/19/15 11:18 AM
04/19/15 11:18 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
It's called rust, caused by humidity [ moisture ] in your garage. If you had a climate control system in your garage you wouldn't have that problem. You forgot the never take it out and drive it part.
Re: Why the rust?
[Re: 4doorSatellite]
#1806914
04/19/15 02:29 PM
04/19/15 02:29 PM
markz528
Morrow, OH
Condensation on your engine caused by a sudden rise in temperature. This usually happens in early spring when warm moist air meets with your still cold car.
That's my guess anyway.
I have my car in an unheated garage and when temperatures start to rise after winter I regularly check if everything is still dry, engine is the first place to check. My garage never exceeds 55% RH.
Re: Why the rust?
[Re: markz528]
#1806938
04/19/15 02:59 PM
04/19/15 02:59 PM
DaytonaTurbo
Manitoba, Canada
I have my car in an unheated garage and when temperatures start to rise after winter I regularly check if everything is still dry, engine is the first place to check. My garage never exceeds 55% RH. That's too damp IMO. I put a dehumidifier in mine to keep it at 35% or less.
