Re: A body dash cluster removal
[Re: stumpy]
#1806464
04/18/15 08:41 PM
04/18/15 08:41 PM
Posts: 43,575 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Squeeze the tab and pull it out. Make sure to drop your steering column by removing the three bolts to the firewall and the three nuts holding the column to the dash frame. It will rotate down enough to pull the cluster from the top. Grab it up top and rotate down on it. Be very careful with the two connectors on either end that plug into the pins, very easy to break a pin off! Also it is best to remove the headlight switch pull knob by reaching under the dash and pushing in the pin that holds the knob bayonet to the switch, you can then pull the bayonet and knob out getting it out of the way. Be careful of the wiper knob also, it can scratch the cluster housing.
JB Rhinehart, Realist
A-Body's RULE!
[Re: GoDartGo]
#1807210
04/19/15 08:42 PM
04/19/15 08:42 PM
Posts: 7,798 Lyons, CO
MileHighDart
Lyons, CO
okay, I got the dash out and took the pad off. Now I am seriously thinking about putting an volt meter in place of the amp meter. does any one have directions, or a schematic for that? I don't have the details for you, but I'd go ahead and do it while you have it out. As you now know its kind of a pain to pull the cluster so take advantage and do it.
