318 rebuild
#1806125
04/18/15 10:25 AM
04/18/15 10:25 AM
Posts: 4,453 Morristown Tn.
71birdJ68
Morristown Tn.
Ok, so if you wanted to do a completely stock factory type of rebuild of a 2 barrel 69 318, whose pistons, and cam would you use?
Re: 318 rebuild
[Re: 71birdJ68]
#1806127
04/18/15 10:29 AM
04/18/15 10:29 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Ok, so if you wanted to do a completely stock factory type of rebuild of a 2 barrow 69 318, wholes pistons, and cam would you use? I'd use pistons without holes, or is it whores? Course my wheel barrow doesn't have a 318.
Re: 318 rebuild
[Re: 71birdJ68]
#1806134
04/18/15 10:45 AM
04/18/15 10:45 AM
Supercuda
About to go away
About to go away
up yours
To answer the question, a complete factory stock type rebuild would use factory pistons and cam. Otherwise it's just a generic rebuild of the aftermarket type.
Re: 318 rebuild
[Re: 71birdJ68]
#1806212
04/18/15 12:28 PM
04/18/15 12:28 PM
Posts: 735 Pa. U.S.A.
moparborn
Pa. U.S.A.
For a basic stock rebuild,low cost replacement parts are adequate. Sealed power pistons and rings will work. If I were you I would step it up a little since you are that far into the motor,more compression,cam,touch up the heads,etc. The motor is getting old,most likely needs fresh valve springs. Oil pump is a given. What is your goal and budget?
Re: 318 rebuild
[Re: moparborn]
#1806218
04/18/15 12:40 PM
04/18/15 12:40 PM
RapidRobert
cheapest would be a basic rebuild kit/Summitt cam. next step up ($$$$) would be some 302 or mag heads & some hughes plateau pistons & additional machining to get quench for an efficient long block. You're only working with 318 cubes & what is the weight of the vehicle it is going into?
Re: 318 rebuild
[Re: 71birdJ68]
#1806278
04/18/15 02:19 PM
04/18/15 02:19 PM
RapidRobert
The bobweight ain't an issue in your case (wont affect smoothness) unless you want/need the new pistons to weigh close enough to the OE ones so that you do not have to rebalance & you do have some leeway there (HF has a cheap digital scale on sale regularly for $10) I would suggest the cheapest rebuild kit you can find (with a few add ons) (pistons/pins/plasma file fit rings/rod/main bearings/cam bearings (maybe)/cam/lifters/gaskets/thin composition head gaskets. tweak the carb/dist after you get it running. read "breakin secrets" at www.mototuneusa.com it'd definitely be a plus if you could bump the SCR with some closed chamber heads or expensive pistons
