pretolite rebuild #1805784
04/17/15 06:59 PM
04/17/15 06:59 PM
California
mickm Offline OP
mickm  Offline OP
California
posted in the general section, not much response.
1 ) what kind of felt should i use in the oil passage?
2) what springs should i use to get the advance in by 2200 or so? and, where do i get the springs from?
thanks...
Re: pretolite rebuild [Re: mickm] #1806887
04/19/15 01:56 PM
04/19/15 01:56 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
the thick felt that is used for wader soles is very similar, but wrong color if that matters to you.
the springs can be a problem, depends on engine build. If you can find a shop with a distributor machine they may have an assortment and be able to set up the dist correctly.
