440 XE274 Dual springs? #1805247
04/16/15 10:02 PM
04/16/15 10:02 PM
CT
P
paulsplymouth Offline OP
P
CT
Hi guys,
I bought a 440 that was running a 509 cam and I am switching it to a XE274 comp cam. The springs in the heads are Comp PN 924-16 duals. Comp calls for a single spring, PN 911-16. A few questions:
Am I pushing my luck running the dual spring? Obviously I would break in with inners removed.
Should I replace with single spring, and will the fact that the heads were machined for dual springs cause any problems?
Thanks!
Paul
Re: 440 XE274 Dual springs? [Re: paulsplymouth] #1805383
04/17/15 01:06 AM
04/17/15 01:06 AM
What will the pressures be at the new installed and open hieghts?
Re: 440 XE274 Dual springs? [Re: paulsplymouth] #1805485
04/17/15 10:43 AM
04/17/15 10:43 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
the 924 spring is gentler than than the 911. the 924 has a lower spring rate but i think it's up to the task. the 924 is recommended for the 275 hi-lift and it's more aggressive than the 274. the 911 is a pretty aggressive single spring. if it were me i'd use the 924 for reliability vs the 911.
Re: 440 XE274 Dual springs? [Re: paulsplymouth] #1805488
04/17/15 10:46 AM
04/17/15 10:46 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
924 comp spring is a good spring for that cam.
125 on the seat with 315 open, @ 1.880 installed. your heads are possibly closer to 1.860 installed height so you should still be ok. No need to remove inner spring, use a good 30 weight brad penn break in oil and a good wix or napa gold oil filter and keep rpm up on start up.
MLR426
