Does anyone make a standard steel 15x7 wheel with 4.25BS? #1805122
04/16/15 06:47 PM
04/16/15 06:47 PM
Colo
P
PJ68RT Offline OP
PJ68RT  Offline OP
P
Colo
I'm looking for standard steel 15x7 wheels with 4.25" back spacing. Wheel Vintiques and Specialty Wheel 15x7 are 4" BS. Specialty has there's listed as 4.25" but I just talked to the guy and they are really only 4".
Thanks for the help
Re: Does anyone make a standard steel 15x7 wheel with 4.25BS? [Re: PJ68RT] #1805132
04/16/15 07:01 PM
04/16/15 07:01 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Talk to www.thewheelsmith.net They do custom offset steel wheels. They built these for me with a custom offset -
Re: Does anyone make a standard steel 15x7 wheel with 4.25BS? [Re: PJ68RT] #1805177
04/16/15 08:00 PM
04/16/15 08:00 PM
Portland, OR
Banzaiii67 Offline
Banzaiii67  Offline
Portland, OR
Re: Does anyone make a standard steel 15x7 wheel with 4.25BS? [Re: PJ68RT] #1805471
04/17/15 10:04 AM
04/17/15 10:04 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Thanks for the help
Doesn't tire size matter here too?
Re: Does anyone make a standard steel 15x7 wheel with 4.25BS? [Re: PJ68RT] #1805515
04/17/15 11:52 AM
04/17/15 11:52 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I'd think there are a few of these in junkyards still. That's where most of mine came from.
Re: Does anyone make a standard steel 15x7 wheel with 4.25BS? [Re: PJ68RT] #1805579
04/17/15 01:37 PM
04/17/15 01:37 PM
Portland, OR
Banzaiii67 Offline
Banzaiii67  Offline
Portland, OR
This wheel/tire simulator to be helpful, not sure if it apply here.
http://www.rimsntires.com/specspro.jsp
Re: Does anyone make a standard steel 15x7 wheel with 4.25BS? [Re: PJ68RT] #1805585
04/17/15 01:43 PM
04/17/15 01:43 PM
Sac, CA
mopowers Online confused
mopowers  Online Confused
Sac, CA
Wheel Vintiques will make a custom offset for about $25 a wheel. FYI
Re: Does anyone make a standard steel 15x7 wheel with 4.25BS? [Re: PJ68RT] #1805603
04/17/15 02:08 PM
04/17/15 02:08 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Anyone know the backspace of the steel wheels used during the 80s on fifth aves and such? I believe they are 15x7.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Does anyone make a standard steel 15x7 wheel with 4.25BS? [Re: Silver70] #1805641
04/17/15 02:53 PM
04/17/15 02:53 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
The 15x7 steel wheels I run from time to time are a 4 1/2" b/s but that was measuring from the inside at the drum to the edge of the wheel lip. If the true b/s is measured at the tire bead these would be a 4" b/s not a 4 1/2". Maybe the op is looking for a true 4 1/2" b/s... shruggy
...FAFO...
Re: Does anyone make a standard steel 15x7 wheel with 4.25BS? [Re: PJ68RT] #1805677
04/17/15 03:42 PM
04/17/15 03:42 PM
Colo
P
PJ68RT Offline OP
PJ68RT  Offline OP
P
Colo
skicker brings up a good point. I believe the correct way to measure backspacing is from the hub mating surface to the inner bead seat. BUT I have seen it also measured from the hub mating surface to the outer edge of the inner flange. So this begs the question..how do wheel vintiques and the others measure the backspacing? Guess i'll make some phone calls. Thanks for the help
Re: Does anyone make a standard steel 15x7 wheel with 4.25BS? [Re: PJ68RT] #1805704
04/17/15 04:42 PM
04/17/15 04:42 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
Yes...... make sure you call to see how the vendor measures it. I was always taught to measure from the mounting surface of the wheel to the inner bead as well. When I ordered custom backspace steel wheels from Summit (don't remember their vendor now) They came in wrong. They asked where I was measuring and when I told them they said they measure to the outer bead. Luckily, they worked for me but I learned something that day.
