Lock-Tight question
#1803711
04/14/15 11:03 PM
04/14/15 11:03 PM
Posts: 1,101 Retired now in Tennessee
Chi_Town_Runner
This is the second time I have lost the mounting screw that mounts the Hurst Shifter Mounting Plate to the trans (three used).
This is the bottom most screw. This screw is exposed. The other two screws are under the shifter mechanism.
I tried lock-tight but the screw still backed out over the course of about a year.
The only thing I can think of is that the lock-Tight (red) does not work with steel threads into aluminum threads.
Anyone know if that's the case or do you have any suggestions?
Thanks Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: Lock-Tight question
[Re: Chi_Town_Runner]
#1803735
04/14/15 11:18 PM
04/14/15 11:18 PM
Chi_Town_Runner
Hey Scratch,
Good point. As I was looking for the screws on Brewers sight he has 2 different lengths. I have a '68 runner so I went with the longer as recommended on his site. Now that you mentioned it I have an "A" body OD trans in the car now. Do you know what the difference in length is? When I installed it, it seemed that the screw seated. I'll go out tomorrow and measure the depth of the hole. Good catch (maybe) I'll also look up the gel-stick I never knew existed. When your old they keep flooding the market with new stuff.
Guess I'll get rid of my Mimi-o-graph paper LOL
How many of these young guys will even know what that is !!!!!
Thanks again Frank
[Re: scratchnfotraction]
#1804535
04/15/15 11:23 PM
04/15/15 11:23 PM
Chi_Town_Runner
Scratch,
Thanks. I've been trying to send you a PM but this new format is giving me grief.
Could you PM me and I could then respond.
Thanks again, Frank
It keeps telling me "all required fields not filled in"
WHAT FIELDS" ugh.
#1804799
04/16/15 09:45 AM
04/16/15 09:45 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Locktite red could be next to impossible to remove. Make sure it's not bottoming, and make sure if you have any driveline vibes you get them figured out. Harmonics can loosen a lot of things that normally wouldn't come loose.
