Help.. '02 RamVan no spark. #180454
01/01/09 02:51 PM
01/01/09 02:51 PM
USA
CrAlt Offline OP
CrAlt  Offline OP
USA
My little brothers 02 ram van stopped running on the way up to NH. He has it towed off to a park-n-ride. He says there is no spark from the coil.
Does the Crankshaft position sensor control that or just the pickup in the dist?
Any common parts that fail on these newer magnum 318's?
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: Help.. '02 RamVan no spark. [Re: CrAlt] #180455
01/01/09 03:17 PM
01/01/09 03:17 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Might be the position sensor??? My dad used to own a 91 Jeep Cherokee and had the same no spark issue and it turned out to be the sensor.
Re: Help.. '02 RamVan no spark. [Re: Neil] #180456
01/01/09 07:45 PM
01/01/09 07:45 PM
ERIE PA home of the RENCH MOB
mike_vango Offline
mike_vango  Offline
i went thru this for two weeks with my 02 van. changing parts checking connections. it was the computer! so keep that in mind.
Re: Help.. '02 RamVan no spark. [Re: mike_vango] #180457
01/01/09 09:04 PM
01/01/09 09:04 PM
USA
CrAlt Offline OP
CrAlt  Offline OP
USA
Turned out to be the coil.
Its guts are all exposed. It looks like the metal core got water in the laments and rusted. Split and busted the plastic. Great design..
Re: Help.. '02 RamVan no spark. [Re: CrAlt] #180458
01/01/09 09:52 PM
01/01/09 09:52 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Planned obsolescence. In the near future you won,t be able to open a hood.
