Jetting Suggestions needed #1804329
04/15/15 06:02 PM
04/15/15 06:02 PM
Brea, Ca
Dart Racer Offline OP
Brea, Ca
I live in So Calif and am headed to Denver for the Night of Fire and Thunder in the middle of May and quite frankly not sure how much jetting change to make to keep the ole Dart running good. Any rule of thumb I can apply to my 500" big block? I have a Demon 1050 on it.
Re: Jetting Suggestions needed [Re: Dart Racer] #1804504
04/15/15 10:58 PM
04/15/15 10:58 PM
PA
ajcasini Offline
ajcasini  Offline
PA
2 jets per 1000' difference.
Re: Jetting Suggestions needed [Re: Dart Racer] #1804528
04/15/15 11:20 PM
04/15/15 11:20 PM
Mark Whitener Offline
a bit much if its gas. Jet per 2000 if it were me.
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: Jetting Suggestions needed [Re: Mark Whitener] #1804589
04/16/15 12:09 AM
04/16/15 12:09 AM
Brea, Ca
Brea, Ca
It is on gas.
Thanks to both for your help. up
Re: Jetting Suggestions needed [Re: Dart Racer] #1804732
04/16/15 03:19 AM
04/16/15 03:19 AM
Cab_Burge Online work
Cab_Burge  Online Work
I use to figure ands use one jet size up on the Holleys going from LACR to Orange County or Bakerapatch. Going to Vegas or Inyokern I would leave it alone,jet it up two sizes at Fremont, Sears Point and Sacramento.That was on Daeco race gas available back then.I would be willing to try one jet size down(leaner) for each 2000 ft increase in density altitude measured on a good weather station work
