Your Opinion on Intakes is Valued! #180416
01/01/09 02:12 PM
01/01/09 02:12 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
I have narrowed it down to the following intakes for a STOCK 69 Charger 440 and would like for this forum to help me decide. Looking for idle-5500/6000 and strictly street use.
*****VERY IMPORTANT THAT IT FITS UNDER THE STOCK HOOD*****
Which Intake??
single choice
Votes accepted starting: 01/01/09 01:11 PM
You must vote before you can view the results of this poll.
Re: Your Opinions Are Valued! *DELETED* [Re: CHRGR69] #180417
01/01/09 02:23 PM
01/01/09 02:23 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Stock street use. Stick with a stock intake. Slight upgrade go with the ch4b. Painted it looks stock but will give you a bit more oomph.
Re: Your Opinions Are Valued! [Re: stumpy] #180418
01/01/09 03:10 PM
01/01/09 03:10 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I guess if its totally "stock", I'm assuming your goal is a restoration type car. In that case, I'd opt for the "stock" intake manifold.
Re: Your Opinions Are Valued! [Re: StealthWedge67] #180419
01/01/09 03:16 PM
01/01/09 03:16 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Its already been restoed. Time for change.
Grandma always said I had "hands of gold"!
Re: Your Opinions Are Valued! [Re: CHRGR69] #180420
01/01/09 03:30 PM
01/01/09 03:30 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Dunno about performance really BUT I'm kinda agree with the rest on keep stock piece UNLESS you get a nice deal around getting cheaper than market prices, someone used or unsatisfied costumer trying to rid off the unit he got.
I'm trying to get an eddy 2186 to my 400 because I want to keep more less stock look and same useage, painting in fact the intake too, but just if I get a DIRTY CHEAP deal, not expecting to pay $200-$250 what is the price.
so I think we are more less on same deal ?
Re: Your Opinion on Intakes is Valued! [Re: CHRGR69] #180421
01/01/09 03:50 PM
01/01/09 03:50 PM
Ohio, USA
Dr-Dave2 Offline
Dr-Dave2  Offline
Ohio, USA
If the rest of the car is truly stock I really dont see much gain by changing the intake only.
In NHRA stock eliminator a 440 charger falls in D/SA or maybe E/SA, they are REQUIRED by the rules to run the stock intake. and the national record is close to mid 10s..... sometimes stock aint so bad...and ( quite possible acid ported )
Re: Your Opinion on Intakes is Valued! [Re: Dr-Dave2] #180422
01/01/09 03:55 PM
01/01/09 03:55 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
You can grow into the Street Dominator when you step up the cam, add headers etc. That's my choice.
Re: Your Opinion on Intakes is Valued! [Re: bobby66] #180423
01/01/09 06:12 PM
01/01/09 06:12 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
The street Dominator works very well on stock apps....never fully understood why it did, but it does.
Can't go wrong with the performer RPM but say good bye to your factory air cleaner.
One you didn't mention is the Awesome Indy 440-2d dual plane which outflows the RPM and with Max wedge porting flows ~360cfm and enough to feed a 700hp motor....this one has the most ultimate potential and sitrs lower than the RPM but it's not on your list.
WIZE
In Car:
Re: Your Opinion on Intakes is Valued! [Re: CHRGR69] #180424
01/01/09 06:34 PM
01/01/09 06:34 PM
Central NC
gch Offline
gch  Offline
Central NC
The street dominator is an awesome intake but loses the stock appearance.
The rpm is great also but taller and non stock appearing also.
The ch4b has been better than expected on my 496(I don't have enough clearance for the rpm and the ch4b has more bottom end and low midrange than the sd in my HEAVY car.It also cleaned up the idle vs the sd in my low compression motor.
It makes good power and is stock appearing if that matters for you.
Re: Your Opinion on Intakes is Valued! [Re: CHRGR69] #180425
01/01/09 07:11 PM
01/01/09 07:11 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
CH4B, a period correct manifold for the 'Day 2' nostalgic look. If it were mine, I'd paint it, makes it easier to wash off any gas strains.
If you have headers, a 230*@.050 or larger cam, a 2800+ stall convertor and are wanting more, go with the Street Dominator.
Re: Your Opinion on Intakes is Valued! [Re: CHRGR69] #180426
01/01/09 11:33 PM
01/01/09 11:33 PM
Wisconsin
coachoff Offline
coachoff  Offline
Wisconsin
Hi
I have tried the Mopar P5153525 intake on my '69 roadrunner and a '70 Coronet 440 and it is crazy tall and won't fit under the stock hood. Tried both a Holly and an AFB carb. If you can find the P4529118 it is basically a stock intake just in aluminum. Don't know why they don't make that anymore.
