will an auto trans get damaged idling on P and N with no oil #1802798
04/13/15 10:46 PM
04/13/15 10:46 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi.
I was at a buddys shop and a car got fired and let idle for a while....but the auto trans was in Park....it idled for about 5 or 10 minutes and then it was put on Neutral to check oil level on the trans and it was almost dry.
Question is....will an automatic transmission het damaged that way or it wont harm a thing unless its put into gear and driven while low on oil ?
Re: will an auto trans get damaged idling on P and N with no oil [Re: domingo] #1802815
04/13/15 10:55 PM
04/13/15 10:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes
wave
Re: will an auto trans get damaged idling on P and N with no oil [Re: MR_P_BODY] #1802822
04/13/15 11:03 PM
04/13/15 11:03 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
yes what??? LOL
Yes it will get damaged?
Yes it wont hurt a thing?
LOL
Re: will an auto trans get damaged idling on P and N with no oil [Re: domingo] #1802826
04/13/15 11:07 PM
04/13/15 11:07 PM
okla.
sam64 Offline
sam64  Offline
okla.
a 727 doesn't circulate fluid in park.so if it had some fluid in it to start with I don't see a problem.
Re: will an auto trans get damaged idling on P and N with no oil [Re: domingo] #1802827
04/13/15 11:08 PM
04/13/15 11:08 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Yes, it will be damaged. The pump is turning any time the engine is running, also the torque convertor should have fluid in it as it can be damaged as well.
Re: will an auto trans get damaged idling on P and N with no oil [Re: 469runner] #1802840
04/13/15 11:20 PM
04/13/15 11:20 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Years ago when I was in dealerships, I heard stories of Torqueflites in cop cars being burnt up by sitting for long periods on hot days, idling in park while watching traffic or taking a nap
Re: will an auto trans get damaged idling on P and N with no oil [Re: CMcAllister] #1803032
04/14/15 04:14 AM
04/14/15 04:14 AM
lake charles, la
sc4400 Offline
sc4400  Offline
lake charles, la
TRANSGO shift kit addresses this issue. It will give full time oiling, filling convertor faster too. You will notice the diffeence if you leave your ride parked for long periods. Worth the 60-70$$
RIP
Re: will an auto trans get damaged idling on P and N with no oil [Re: sc4400] #1803041
04/14/15 05:40 AM
04/14/15 05:40 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Park - damage
Neutral - no damage
fluid will flow in neutral but not park, unless the transgo kit mentioned above is used
Re: will an auto trans get damaged idling on P and N with no oil [Re: sam64] #1803134
04/14/15 11:46 AM
04/14/15 11:46 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Nevermind.
'63 Dodge 330
11.19 @ 121 mph
Re: will an auto trans get damaged idling on P and N with no oil [Re: B5 Bee] #1803144
04/14/15 12:11 PM
04/14/15 12:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By B5 Bee
Park - damage
Neutral - no damage
He did say NO FLUID in it... the fiber stuff in it will be
history(the fiber type thrust parts).. the bands and clutches
shouldnt be a issue... my self... I'd chance it.. fill it up
and see what ya got... as said.. the cop cars did/do have issues
sitting for long periods in park... the cop cars also have a
lock out so they cant be pulled down into low/1st gear.. the
cops had issues of FORGETTING to shift out of low
wave
Re: will an auto trans get damaged idling on P and N with no oil [Re: GY3] #1803185
04/14/15 01:15 PM
04/14/15 01:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Nevermind.
don't nevermind ... say it ...
The 727 does circulate fluid in park, but not nearly as much as it does in neutral.
Re: will an auto trans get damaged idling on P and N with no oil [Re: JohnRR] #1803222
04/14/15 01:54 PM
04/14/15 01:54 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Nevermind.
I was being rude.
It really depends on how much fluid was in it. It could still be low on the dipstick and get enough lubrication to not cause damage.
NEVER run an engine with a DRY torqueflite behind it! ...even in Park.
'63 Dodge 330
11.19 @ 121 mph
Re: will an auto trans get damaged idling on P and N with no oil [Re: domingo] #1803292
04/14/15 03:10 PM
04/14/15 03:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By domingo
it was almost dry.
Almost dry actually or just low on the dipstick? There can be no fluid showing on the dipstick but still enough fluid to prevent major damage.
Re: will an auto trans get damaged idling on P and N with no oil [Re: John_Kunkel] #1804410
04/15/15 08:30 PM
04/15/15 08:30 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
>It was low....probably just 2 quarts and whaterbver was left inside the converter....
Filled it up and it works....
