Re: will an auto trans get damaged idling on P and N with no oil
[Re: 469runner]
#1802840
04/13/15 11:20 PM
04/13/15 11:20 PM
Posts: 11,583 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Years ago when I was in dealerships, I heard stories of Torqueflites in cop cars being burnt up by sitting for long periods on hot days, idling in park while watching traffic or taking a nap
[Re: sam64]
#1803134
04/14/15 11:46 AM
04/14/15 11:46 AM
Posts: 4,680 Wichita
GY3
Wichita
a 727 doesn't circulate fluid in park.so if it had some fluid in it to start with I don't see a problem. Nevermind.
[Re: B5 Bee]
#1803144
04/14/15 12:11 PM
04/14/15 12:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Park - damage Neutral - no damage
fluid will flow in neutral but not park, unless the transgo kit mentioned above is used He did say NO FLUID in it... the fiber stuff in it will be history(the fiber type thrust parts).. the bands and clutches shouldnt be a issue... my self... I'd chance it.. fill it up and see what ya got... as said.. the cop cars did/do have issues sitting for long periods in park... the cop cars also have a lock out so they cant be pulled down into low/1st gear.. the cops had issues of FORGETTING to shift out of low
[Re: GY3]
#1803185
04/14/15 01:15 PM
04/14/15 01:15 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
a 727 doesn't circulate fluid in park.so if it had some fluid in it to start with I don't see a problem. Nevermind. don't nevermind ... say it ... The 727 does circulate fluid in park, but not nearly as much as it does in neutral.
[Re: JohnRR]
#1803222
04/14/15 01:54 PM
04/14/15 01:54 PM
GY3
Wichita
a 727 doesn't circulate fluid in park.so if it had some fluid in it to start with I don't see a problem. Nevermind. don't nevermind ... say it ... The 727 does circulate fluid in park, but not nearly as much as it does in neutral. I was being rude. It really depends on how much fluid was in it. It could still be low on the dipstick and get enough lubrication to not cause damage. NEVER run an engine with a DRY torqueflite behind it! ...even in Park.
[Re: domingo]
#1803292
04/14/15 03:10 PM
04/14/15 03:10 PM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Almost dry actually or just low on the dipstick? There can be no fluid showing on the dipstick but still enough fluid to prevent major damage.
