balancer selection help please
#1801858
04/12/15 07:20 PM
04/12/15 07:20 PM
Posts: 807 Toronto, Canada
dirtybee
Toronto, Canada
Hi everyone, I'm shopping for an aftermarket balancer as an upgrade from stock on my 500" stroker low deck street and strip 70 coronet. It has gone 11.70 @ 114 so I want something good. I'm looking at ATI superdamper, looks like 917122E fits a stock timing cover but pulley alignment is gone, it is a steel shell with a 3 ring design, is there an off the shelf pulley to fix this for water pump and alternator? Otherwise it's 917470E which is an aluminum shell with 2 not 3 ring design, looks like it fits a stock pulley system, does this one sacrifice performance for fittment? I also looked at ATI Rattler, looks like a solid product, any experience with one? Then Summit has a street/strip 18.1 sfi for $150 and a race sfi for $300, I was looking at both. Any suggestions or knowledge would be great, thx
Re: balancer selection help please
[Re: dirtybee]
#1801969
04/12/15 09:42 PM
04/12/15 09:42 PM
Posts: 289 Lowes
steve660
Lowes
I,ve used Fluidamper #720311 and had no problem with pulley alignment. This was on a 9 sec stroker engine and have had no problems with it. It is pricey but its another option.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: BSB67]
#1801972
04/12/15 09:46 PM
04/12/15 09:46 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Do not buy the Summit brand bracket racer balancer. I tried one and it spun without much run time on it.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
