balancer selection help please #1801858
04/12/15 07:20 PM
04/12/15 07:20 PM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
Hi everyone, I'm shopping for an aftermarket balancer as an upgrade from stock on my 500" stroker low deck street and strip 70 coronet. It has gone 11.70 @ 114 so I want something good. I'm looking at ATI superdamper, looks like 917122E fits a stock timing cover but pulley alignment is gone, it is a steel shell with a 3 ring design, is there an off the shelf pulley to fix this for water pump and alternator? Otherwise it's 917470E which is an aluminum shell with 2 not 3 ring design, looks like it fits a stock pulley system, does this one sacrifice performance for fittment? I also looked at ATI Rattler, looks like a solid product, any experience with one? Then Summit has a street/strip 18.1 sfi for $150 and a race sfi for $300, I was looking at both. Any suggestions or knowledge would be great, thx
Re: balancer selection help please [Re: dirtybee] #1801933
04/12/15 09:04 PM
04/12/15 09:04 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I think that the 470E will be plenty good enough for your application, IMO.
Re: balancer selection help please [Re: BSB67] #1801950
04/12/15 09:26 PM
04/12/15 09:26 PM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
thx for the reply, have you used this balancer before?
Re: balancer selection help please [Re: dirtybee] #1801969
04/12/15 09:42 PM
04/12/15 09:42 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
I,ve used Fluidamper #720311 and had no problem with pulley alignment. This was on a 9 sec stroker engine and have had no problems with it. It is pricey but its another option.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: balancer selection help please [Re: BSB67] #1801972
04/12/15 09:46 PM
04/12/15 09:46 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Do not buy the Summit brand bracket racer balancer. I tried one and it spun without much run time on it.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: balancer selection help please [Re: dirtybee] #1802048
04/12/15 10:56 PM
04/12/15 10:56 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Yes. It is on my Charger.
Re: balancer selection help please [Re: dirtybee] #1802060
04/12/15 11:08 PM
04/12/15 11:08 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Had a TCI Rattler on my RB 498 forever. Can't say as to whether pulley alignment would be an issue as I only had a low mount alternator bracket on it.
Re: balancer selection help please [Re: dirtybee] #1802109
04/13/15 12:06 AM
04/13/15 12:06 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use this Pro/Sport balancer on my 63 and a few other engines. They are made in Austrailia and it has worked flawless on my 63. And the stock pulleys all line up normal. Ron
http://www.manciniracing.com/prosport1.html
Re: balancer selection help please [Re: 383man] #1802182
04/13/15 02:23 AM
04/13/15 02:23 AM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
thx for all the replies, i'm going with the aluminum ATI
Re: balancer selection help please [Re: dirtybee] #1802517
04/13/15 05:42 PM
04/13/15 05:42 PM
AndyF Offline
AndyF  Offline
The short pulley from Doty will work with at least one of the ATI dampers.
ATI could sell more dampers if they sold a matching pulley. I've told them that a couple of times but they choose not to listen to me. Making custom pullies wouldn't be that hard of a job for ATI, they have the CNC equipment and the CAD data so all they have to do is program the machine and push the button.
