new indys owner #180019
12/31/08 09:53 PM
12/31/08 09:53 PM
tampa, fl
MaxAxe3 Offline OP
MaxAxe3  Offline OP
tampa, fl
after installing my indys on my 440 with the outside oiling for the heads i notice my oil pressure is down a lot was 65+/- @ idle, now about 28 +/- @ idle..is it necessary to install a reducer in the oil line to restrict the flow to the heads??? i don't want to empty the oil pan @ 6500 rpm!! or is this normal..when i up the rpm in neutral the pressure comes up to around 60lbs@ 2500 rpm..its all new, i don't need to lose it..thanks in advance
4913856-HEADSUP.eml (146 downloads)
Re: new indys owner [Re: MaxAxe3] #180020
12/31/08 09:56 PM
12/31/08 09:56 PM
long island NY
Ari440 Online content
Ari440  Online Content
long island NY
yes
I have a #70 jet size in mine
1.39 9.85 - 137 mph
Re: new indys owner [Re: Ari440] #180021
12/31/08 09:58 PM
12/31/08 09:58 PM
tampa, fl
MaxAxe3 Offline OP
MaxAxe3  Offline OP
tampa, fl
where would you install a jet??
Re: new indys owner [Re: MaxAxe3] #180022
12/31/08 10:03 PM
12/31/08 10:03 PM
long island NY
long island NY
the two oil line fittings that are on the heads
drill and tap them on the back side
there is room for them in the heads
I do not remeber the drill and tap size but get a holly jet and you need to tap it at that size
someone else should know it too
1.39 9.85 - 137 mph
Re: new indys owner [Re: Ari440] #180023
12/31/08 10:05 PM
12/31/08 10:05 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
everyone has their own cure to fix this problem. mine is a very low $$ cure. i sandwiched a 1/4"copper flare cap between the flare fitting on the head & the flexi hose connection. i drilled a hole in these caps to 7/64" & my low press while hot @ idle has gone. these caps are used in the refrigeration industry & cost me 10 cents. you can try a smaller hole if you desire as it doesn't cost anything to enlarge them.
Re: new indys owner [Re: Ari440] #180024
12/31/08 10:06 PM
12/31/08 10:06 PM
tampa, fl
MaxAxe3 Offline OP
MaxAxe3  Offline OP
tampa, fl
so you pull the fitting out and tap the rear of the fitting and reinstall??!! sounds pretty simple, just like me!! will give it a go....thanks a bunch!!
Re: new indys owner [Re: MaxAxe3] #180025
12/31/08 10:13 PM
12/31/08 10:13 PM
long island NY
long island NY
yes ........ .........good to go !!!!
1.39 9.85 - 137 mph
Re: new indys owner [Re: Ari440] #180026
12/31/08 10:48 PM
12/31/08 10:48 PM
NC
440Jim Offline
440Jim  Offline
NC
Anything with a hole size roughly 0.062" or so.
Remember that Holley jet is an extra-fine thread 1/4-32 (fine is 1/4-28, and coarse is 1/4-20. So get the right tap.
Re: new indys owner [Re: MaxAxe3] #180027
12/31/08 10:52 PM
12/31/08 10:52 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You can also use a nitrous fitting and a nitrous jet.
Re: new indys owner [Re: MaxAxe3] #180028
01/01/09 03:12 AM
01/01/09 03:12 AM
fullmetaljacket Offline
Are all Indy's like this?
My SRs never gave me any low oil pressure at idle or low speeds. SR's have external oiling lines also.
If I wasn't experiencing any low oil pressure problems, than was I over looking another problem with good strong pressure and or flow at the heads?
Cold starts would be at 70-80 pounds, warmed up and at highway speeds 40-60 pounds. 25-30 at curb Idle.
Re: new indys owner [Re: fullmetaljacket] #180029
01/01/09 08:10 AM
01/01/09 08:10 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
my sr,s on my street car never give me a prob and my ez 325,s on my race car work great too with no ristrictors.
Re: new indys owner [Re: MaxAxe3] #180030
01/01/09 11:47 PM
01/01/09 11:47 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Indy has new ownership?
Re: new indys owner [Re: jcc] #180031
01/02/09 03:47 PM
01/02/09 03:47 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Didn't you hear? Russ sold out to Eddie and he is going to fix all the problems.
Damon
Re: new indys owner [Re: mopardamo] #180032
01/03/09 03:22 AM
01/03/09 03:22 AM
Tampa, Fl
valiantboy Offline
super gas
valiantboy  Offline
super gas
Tampa, Fl
eddie? as in elvis eddie? 1fastmopar? really? maybe there will be hope for indy products yet!
I'm WAY too baked to drive to the devil's house.
Re: new indys owner [Re: valiantboy] #180033
01/03/09 10:24 AM
01/03/09 10:24 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i think sombady is pull your chain
Re: new indys owner [Re: rebel] #180034
01/03/09 11:46 AM
01/03/09 11:46 AM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
That is a good idea! I don't run Indy heads But I've used those caps at work and they would work great for that.
Re: new indys owner [Re: 66er] #180035
01/04/09 10:19 PM
01/04/09 10:19 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
Thanks for the info and pictures on this guys! This is why I love Moparts. I was just putting together my motor yesterday and while pre-oiling I realized I had too much oil going to the head so I posted a question on Moparts and within minutes I had good useful info and a link to this thread. (First set of Indy -1s so I didn't know this was necessary)
Using the Holley jet was what I was thinking about and you guys confirmed it and 440Jim had pictures (of course...) Problem solved, motor installed, fired up, Cam broken in and ready for the '09 season!
I didn't have any spare #70s so I used a #74,it's close to .080 but that's still way better than an unrestricted #4 fitting.
I didn't have a 1/4-32 tap and couldn't find one on Saturday but I had an extra fitting and tried a 1/4-28 tap and it worked just fine as well. The jet started and made about 1 1/2 turns and then got a little snug, but since it won't be coming out and getting stuck is a good thing I just put it in the vise and used a good sized slot screw driver and it went right in (used lock tight too).
Thought I'd share that because most of us will have 1/4-28 taps but 1/4-32 taps can be hard to find.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: new indys owner [Re: WadeMetzinger] #180036
01/05/09 09:08 AM
01/05/09 09:08 AM
Colorado
506RR Offline
506RR  Offline
Colorado
Great Info Guys!
