Re: new indys owner
[Re: MaxAxe3]
#180022
12/31/08 10:03 PM
12/31/08 10:03 PM
Posts: 5,620 long island NY
Ari440
long island NY
the two oil line fittings that are on the heads
drill and tap them on the back side
there is room for them in the heads
I do not remeber the drill and tap size but get a holly jet and you need to tap it at that size
someone else should know it too
1.39 9.85 - 137 mph
Re: new indys owner
[Re: jcc]
#180031
01/02/09 03:47 PM
01/02/09 03:47 PM
Posts: 1,328 St. Louis, MO
mopardamo
St. Louis, MO
Indy has new ownership?
Didn't you hear? Russ sold out to Eddie and he is going to fix all the problems.
Damon
Re: new indys owner
[Re: valiantboy]
#180033
01/03/09 10:24 AM
01/03/09 10:24 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
eddie? as in elvis eddie? 1fastmopar? really? maybe there will be hope for indy products yet!
i think sombady is pull your chain
Re: new indys owner
[Re: rebel]
#180034
01/03/09 11:46 AM
01/03/09 11:46 AM
Posts: 370 Real North Cal.
66er
Real North Cal.
everyone has their own cure to fix this problem. mine is a very low $$ cure. i sandwiched a 1/4"copper flare cap between the flare fitting on the head & the flexi hose connection. i drilled a hole in these caps to 7/64" & my low press while hot @ idle has gone. these caps are used in the refrigeration industry & cost me 10 cents. you can try a smaller hole if you desire as it doesn't cost anything to enlarge them.
That is a good idea! I don't run Indy heads But I've used those caps at work and they would work great for that.
Re: new indys owner
[Re: 66er]
#180035
01/04/09 10:19 PM
01/04/09 10:19 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Thanks for the info and pictures on this guys! This is why I love Moparts. I was just putting together my motor yesterday and while pre-oiling I realized I had too much oil going to the head so I posted a question on Moparts and within minutes I had good useful info and a link to this thread. (First set of Indy -1s so I didn't know this was necessary) Using the Holley jet was what I was thinking about and you guys confirmed it and 440Jim had pictures (of course...) Problem solved, motor installed, fired up, Cam broken in and ready for the '09 season! I didn't have any spare #70s so I used a #74,it's close to .080 but that's still way better than an unrestricted #4 fitting. I didn't have a 1/4-32 tap and couldn't find one on Saturday but I had an extra fitting and tried a 1/4-28 tap and it worked just fine as well. The jet started and made about 1 1/2 turns and then got a little snug, but since it won't be coming out and getting stuck is a good thing I just put it in the vise and used a good sized slot screw driver and it went right in (used lock tight too). Thought I'd share that because most of us will have 1/4-28 taps but 1/4-32 taps can be hard to find.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
