Tolerance of pilot bushing on input shaft #1799204
04/09/15 10:05 AM
04/09/15 10:05 AM
Ashland City, Tennessee
Aar1064 Offline OP
Aar1064  Offline OP
I'm getting ready to install new pilot bushing and trying to determine if The ID is within tolerance of input shaft. It feels loose to me but maybe it should be.
Thanks Moparts
Re: Tolerance of pilot bushing on input shaft [Re: Aar1064] #1799263
04/09/15 11:30 AM
04/09/15 11:30 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What is "loose" ??
Re: Tolerance of pilot bushing on input shaft [Re: Aar1064] #1799418
04/09/15 02:39 PM
04/09/15 02:39 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
When holding it in your hand the ID will feel loose.
It is a thin bushing and a press fit into the crank. It will compress a bit when installed and tighten up on the shaft.
- Stu Harmon
Re: Tolerance of pilot bushing on input shaft [Re: feets] #1799964
04/10/15 12:55 AM
04/10/15 12:55 AM
Aar1064 Offline OP
Aar1064  Offline OP
Didn't think of that and it makes perfect sense.
Re: Tolerance of pilot bushing on input shaft [Re: Stanton] #1799973
04/10/15 12:59 AM
04/10/15 12:59 AM
Aar1064 Offline OP
Aar1064  Offline OP
I placed a piece of notebook paper around the shaft and slip bushing on and had some resistance with no play if that helps answer your question.
Re: Tolerance of pilot bushing on input shaft [Re: Aar1064] #1800024
04/10/15 02:12 AM
04/10/15 02:12 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I had to ream my pilot bushing after install.
