Re: Tolerance of pilot bushing on input shaft
[Re: Aar1064]
#1799418
04/09/15 02:39 PM
04/09/15 02:39 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
When holding it in your hand the ID will feel loose.
It is a thin bushing and a press fit into the crank. It will compress a bit when installed and tighten up on the shaft.
