R3 roller lifter question #1797316
04/07/15 01:13 PM
04/07/15 01:13 PM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
I just picked up an R3 small block with stock style 59 degree lifter angles. If I decide to go with a roller cam combo on this build is there a roller lifter available to clear the block. Everything I read warns against grinding the block for tie bar clearance as you WILL hit water.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: R3 roller lifter question [Re: pittsburghracer] #1797331
04/07/15 01:19 PM
04/07/15 01:19 PM
408Dust Offline
408Dust  Offline
Have to clearance it no matter what.I did both of mine by hand no problem and use lifters from comp.
Re: R3 roller lifter question [Re: pittsburghracer] #1797375
04/07/15 02:01 PM
04/07/15 02:01 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Did mine no problems but it's 48°
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: R3 roller lifter question [Re: pittsburghracer] #1797436
04/07/15 02:52 PM
04/07/15 02:52 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
You need some nice W9 heads now.... I think I can help smile
Take that wing off the duster yet?
Re: R3 roller lifter question [Re: SpareParts] #1797459
04/07/15 03:18 PM
04/07/15 03:18 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
LOL Not giving up on the wing. I wish I had about 10 of them things.
One day I will have something cool here.
Re: R3 roller lifter question [Re: sdaurity] #1797504
04/07/15 03:55 PM
04/07/15 03:55 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Never give up!! Lol I wish I had just one
Re: R3 roller lifter question [Re: SpareParts] #1797644
04/07/15 05:50 PM
04/07/15 05:50 PM
PA.
"Little"John
"Little"John
PA.
The wing is still at rest on the car for the 2015 race season. And as far as grinding the block I have a sonic checker so I guess I will do some testing but I see a block on ebay right now were their grinding did not end well.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: R3 roller lifter question [Re: pittsburghracer] #1797722
04/07/15 07:02 PM
04/07/15 07:02 PM
Renton Washington
Triple Threat Offline
Renton Washington
My 59 degree R3 had the lifter bosses milled down for clearance. Comp 8043 lifters.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: R3 roller lifter question [Re: pittsburghracer] #1798083
04/08/15 12:01 AM
04/08/15 12:01 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
from the dept of I know absolutely nothing.... why were the 59 degree blocks not set up for roller lifters?
Re: R3 roller lifter question [Re: J_BODY] #1798098
04/08/15 12:10 AM
04/08/15 12:10 AM
PA.
"Little"John
"Little"John
PA.
And that my Friend is the million dollar question. Who the heck designs some of this stuff?????
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: R3 roller lifter question [Re: pittsburghracer] #1798130
04/08/15 12:21 AM
04/08/15 12:21 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I ground my factory block for roller lifters had no problem there.
Re: R3 roller lifter question [Re: 1967dartgt] #1798168
04/08/15 12:43 AM
04/08/15 12:43 AM
PA.
"Little"John
"Little"John
PA.
Ya I am stepping up from a 550 lift solid to a 650 lift roller cam this year and just finished grinding my stock block but mother mopar warns against it on the 59 degree R3 blocks so I thought I would throw this out there. Like I said there is one on eBay right now that they hit water and did an epoxy repair. It's for sale and they bought a 48 degree block
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: R3 roller lifter question [Re: pittsburghracer] #1798185
04/08/15 01:00 AM
04/08/15 01:00 AM
408Dust Offline
408Dust  Offline
Used for NASCAR no rollers just solid cams, have the lifters you are going to use and start grinding. Most people hit water when they clearance them with a CNC or Bridgeport.
Re: R3 roller lifter question [Re: pittsburghracer] #1798301
04/08/15 06:26 AM
04/08/15 06:26 AM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
John,you not only have to clearance the block but you have to take into account that the lifter bore is .400 taller than a stock block,so you have to get a taller lifter or grind the top of the bore down so a conventional lifter will fit. These R3 blocks where designed from the beginning to be 48* and where cast with 6 bolts around each cylinder. They where converted to 59* as an afterthought, the lifter bore was moved closer in to the block to be 59* and the extra bolt bosses around the cylinders where milled off. What you have to watch for is that there are water passages running through the unused bolt bosses that you have to clearance for the lifter tie bars. What I did was used the rivet on the tie bar as my clearance point and I hand fit each lifter allowing a couple of thousands behind the rivet. If you just go in there hog wild with a grinder or Bridgeport you will hit water. Make sure you attach a piece of wood or something to the deck surface, it is very easy for the grinder to jump out of the valley near the top and nick the deck.-Randy
Re: R3 roller lifter question [Re: pittsburghracer] #1798448
04/08/15 01:10 PM
04/08/15 01:10 PM
PA.
"Little"John
"Little"John
PA.
Thanks Randy. I just installed the roller cam you gave me and got her all degreed in and can't wait to see how it runs. I'll bet this engine won't run out of steam at 1000 foot like it did before. Thanks again.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: R3 roller lifter question [Re: pittsburghracer] #1798454
04/08/15 01:12 PM
04/08/15 01:12 PM
PA.
"Little"John
"Little"John
PA.
This R3 block still has the bosses for the extra head bolts and they were drilled and tapped.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: R3 roller lifter question [Re: pittsburghracer] #1798459
04/08/15 01:23 PM
04/08/15 01:23 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Had mine done by Ryan at Shadydell.
Because is a 59 deg ,the taller the lift the more crappy angle you will have.
My block looked like he took and endball mill and plunged cut the boss area. Still required clearancing from my machinist.
Re: R3 roller lifter question [Re: pittsburghracer] #1798535
04/08/15 03:10 PM
04/08/15 03:10 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
If it's like the R1 I had it'll have the bolt holes on the bottom side but not above the cylinders, those were removed to clear 59* push rods it looked like
Re: R3 roller lifter question [Re: SpareParts] #1800375
04/10/15 03:51 PM
04/10/15 03:51 PM
408Dust Offline
408Dust  Offline
FYI
mccoy valley oil drain.JPG (2548 downloads)
Re: R3 roller lifter question [Re: pittsburghracer] #2649102
04/26/19 01:50 AM
04/26/19 01:50 AM
Pennsylvania, United States
sk3406 Offline
sk3406  Offline
My resto was machined for rollers. It takes the tall rollers. we have no problems with it. Big solid roller the lobes have ice caps. What we did have a problem with was the T&D rockers were hitting the retainers on some but not all. They were so far out some didn't have to be cut . He made a fixture to cut the rockers on a rotary table. You can see the difference. We drove and raced it for 6 years with it hitting on most..
