R3 roller lifter question
#1797316
04/07/15 01:13 PM
04/07/15 01:13 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I just picked up an R3 small block with stock style 59 degree lifter angles. If I decide to go with a roller cam combo on this build is there a roller lifter available to clear the block. Everything I read warns against grinding the block for tie bar clearance as you WILL hit water.
Re: R3 roller lifter question
[Re: pittsburghracer]
#1797331
04/07/15 01:19 PM
04/07/15 01:19 PM
Posts: 739 Florida
408Dust
Have to clearance it no matter what.I did both of mine by hand no problem and use lifters from comp.
[Re: SpareParts]
#1797459
04/07/15 03:18 PM
04/07/15 03:18 PM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
You need some nice W9 heads now.... I think I can help Take that wing off the duster yet? LOL Not giving up on the wing. I wish I had about 10 of them things.
One day I will have something cool here.
[Re: SpareParts]
#1797644
04/07/15 05:50 PM
04/07/15 05:50 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The wing is still at rest on the car for the 2015 race season. And as far as grinding the block I have a sonic checker so I guess I will do some testing but I see a block on ebay right now were their grinding did not end well.
[Re: J_BODY]
#1798098
04/08/15 12:10 AM
04/08/15 12:10 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
from the dept of I know absolutely nothing.... why were the 59 degree blocks not set up for roller lifters? And that my Friend is the million dollar question. Who the heck designs some of this stuff?????
#1798130
04/08/15 12:21 AM
04/08/15 12:21 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I ground my factory block for roller lifters had no problem there.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1798168
04/08/15 12:43 AM
04/08/15 12:43 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Ya I am stepping up from a 550 lift solid to a 650 lift roller cam this year and just finished grinding my stock block but mother mopar warns against it on the 59 degree R3 blocks so I thought I would throw this out there. Like I said there is one on eBay right now that they hit water and did an epoxy repair. It's for sale and they bought a 48 degree block
#1798185
04/08/15 01:00 AM
04/08/15 01:00 AM
Posts: 739 Florida
408Dust
from the dept of I know absolutely nothing.... why were the 59 degree blocks not set up for roller lifters? And that my Friend is the million dollar question. Who the heck designs some of this stuff????? Used for NASCAR no rollers just solid cams, have the lifters you are going to use and start grinding. Most people hit water when they clearance them with a CNC or Bridgeport.
#1798448
04/08/15 01:10 PM
04/08/15 01:10 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks Randy. I just installed the roller cam you gave me and got her all degreed in and can't wait to see how it runs. I'll bet this engine won't run out of steam at 1000 foot like it did before. Thanks again.
#1798454
04/08/15 01:12 PM
04/08/15 01:12 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
This R3 block still has the bosses for the extra head bolts and they were drilled and tapped.
#1798459
04/08/15 01:23 PM
04/08/15 01:23 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Thanks Randy. I just installed the roller cam you gave me and got her all degreed in and can't wait to see how it runs. I'll bet this engine won't run out of steam at 1000 foot like it did before. Thanks again. Had mine done by Ryan at Shadydell. Because is a 59 deg ,the taller the lift the more crappy angle you will have. My block looked like he took and endball mill and plunged cut the boss area. Still required clearancing from my machinist.
#1798535
04/08/15 03:10 PM
04/08/15 03:10 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
This R3 block still has the bosses for the extra head bolts and they were drilled and tapped. If it's like the R1 I had it'll have the bolt holes on the bottom side but not above the cylinders, those were removed to clear 59* push rods it looked like
#2649102
04/26/19 01:50 AM
04/26/19 01:50 AM
Posts: 37 Pennsylvania, United States
sk3406
My resto was machined for rollers. It takes the tall rollers. we have no problems with it. Big solid roller the lobes have ice caps. What we did have a problem with was the T&D rockers were hitting the retainers on some but not all. They were so far out some didn't have to be cut . He made a fixture to cut the rockers on a rotary table. You can see the difference. We drove and raced it for 6 years with it hitting on most..
