TPMS valve stem replacement #1797017
04/05/15 10:02 PM
04/05/15 10:02 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
Working on 2010 Avenger. The valve stem is cracked and wondering if you can replace valve stem in TPMS. I checked Advance and they have replacement valve stems for there in house TPMS.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: TPMS valve stem replacement [Re: steve660] #1797018
04/05/15 10:17 PM
04/05/15 10:17 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Just did a google search on it, appears they are serviceable, dorman has a stem replacement kit for 5 bux i think. If it doesnt pan out, the sensors are as low as 5 dollars...
Re: TPMS valve stem replacement [Re: moparjim79] #1797019
04/05/15 10:21 PM
04/05/15 10:21 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
Yes, that's the one I found at Advance, they were $5. Their TPMS were $55.00
Re: TPMS valve stem replacement [Re: steve660] #1797020
04/05/15 10:25 PM
04/05/15 10:25 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
If buying from advance is more of a convenience, then pull the trigger, but they have oem replacements cheaper online. If the stem repair fuxes it thats great, otherwise, even if you replace the sensor, a stealership still has to program it
Re: TPMS valve stem replacement [Re: moparjim79] #1797021
04/06/15 01:18 AM
04/06/15 01:18 AM
Missouri
MOBodyman Offline
MOBodyman  Offline
Missouri
Why? Are the ones from Advance different? I bought an extra set of wheels for my 2010 Ram 1500 and a set of new oem sensors off of ebay. I just installed the sensors in the new wheels, mounted the tires, and drove a few miles and everything was good to go.
Dallas
2012 Rallye Redline Challenger, 1st new car!
2010 Ram 1500 4wd HEMI-hauler
2014 Dodge Dart-gas saver
4 projects and a bunch of parts cars, losing interest since buying the Challenger lol
1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: TPMS valve stem replacement [Re: MOBodyman] #1797022
04/06/15 03:25 AM
04/06/15 03:25 AM
Indy
mike Offline
mike  Offline
Indy
I just replaced a broken sensor on my wife's 09 Journey. she had to drive it about 3 miles before the light went off
'69 Dart
'14 Ram 1500
'09 Journey R/T
Re: TPMS valve stem replacement [Re: mike] #1797023
04/06/15 08:17 AM
04/06/15 08:17 AM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
Mike....did you buy one from a Dealer or from auto parts store?
Re: TPMS valve stem replacement [Re: steve660] #1797024
04/06/15 08:31 AM
04/06/15 08:31 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
I've had mine replaced at Discount Tire when they installed new tires. Drove it home and by that time the light went out. Doubt they carry OEM ones.
Re: TPMS valve stem replacement [Re: steve660] #1797160
04/07/15 10:01 AM
04/07/15 10:01 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Sorry guys, couldn't reply... It was presumptuous of me to think the avenger was the same as my 2012 charger, only reason I saids..
Re: TPMS valve stem replacement [Re: MI_Custumz] #1797231
04/07/15 11:46 AM
04/07/15 11:46 AM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
Same here. Discount tire installed their TPMS , flashed it and works good. Plus theirs you can replace just the valve stem if it cracks...cool! It was $55 installed too.
