Hemi main bearings #1796876
04/05/15 02:28 PM
04/05/15 02:28 PM
Lanse,mi
Canam800 Offline OP
Canam800  Offline OP
Lanse,mi
I'm getting the main bearings for my world iron hemi block. Will the speed pro 119m bearings fit. They say 440. What is the difference between hemi and 440 main bearings? I am using a Callies crank
Thanks Brandon
Re: Hemi main bearings [Re: Canam800] #1796877
04/05/15 02:39 PM
04/05/15 02:39 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
All RB and Hemi take the same main bearing with the exception of some RBs that had a larger thrust side flanges.The standard flange could be use on those also.The 119 bearing is 3/4 groove and best suitable for street/strip use.
Re: Hemi main bearings [Re: Canam800] #1796878
04/05/15 03:02 PM
04/05/15 03:02 PM
I like and use the Federal Mogul, Seal Power #4095M which are a narrow full groove tri metal main set listed as truck bearings, they work good, last a long time
Re: Hemi main bearings [Re: Cab_Burge] #1796879
04/05/15 04:01 PM
04/05/15 04:01 PM
Lanse,mi
Canam800 Offline OP
Canam800  Offline OP
Lanse,mi
Ok thanks guys. This is a mostly street 572 with an f2 procharger
Re: Hemi main bearings [Re: Canam800] #1796880
04/05/15 04:14 PM
04/05/15 04:14 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
The 119M is a fine bearing for that engine. It's a softer style higher babbitt bearing so it won't last as long as one of my favorites the Clevite MS-2233HG coated by Calico.
Re: Hemi main bearings [Re: Mopar_Rich] #1796881
04/06/15 02:24 AM
04/06/15 02:24 AM
Australia
Teamx Offline
Teamx  Offline
Australia
the world blocks are machined to take the larger thrust bearing, you may wish to take advantage of this, however the small thrust will still work
Re: Hemi main bearings [Re: Canam800] #1798447
04/08/15 01:09 PM
04/08/15 01:09 PM
NC
440Jim Offline
440Jim  Offline
NC
Another option (that I use in my drag race blocks) is the Clevite MS1277HG. 1974 and newer blocks with the large thrust surface, full groove.
