Vacuum advance #1794755
04/02/15 02:30 AM
04/02/15 02:30 AM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
Does anybody make an adjustable vacuum advance that will work with a point style BB distributor?
Re: Vacuum advance [Re: 71birdJ68] #1794756
04/02/15 10:20 AM
04/02/15 10:20 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Which points distributor ?
Re: Vacuum advance [Re: 62maxwgn] #1794757
04/02/15 11:00 AM
04/02/15 11:00 AM
Morristown Tn.
Morristown Tn.
The standard mopar single point distributor. I'm putting a Pertronix unit in it, and would like to have a better than stock vacuum advance.
Re: Vacuum advance [Re: 71birdJ68] #1794758
04/02/15 12:34 PM
04/02/15 12:34 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If it's like top left,it is already adjustable with 1/8" allen wrench.
Re: Vacuum advance [Re: 71birdJ68] #1794759
04/02/15 01:20 PM
04/02/15 01:20 PM
As said you can adj how fast the can comes in with a 3/32" allen wrench (CCW gives less adv at a given in hg but the total a can offers stays the same) & 11 (the total) for example stamped on the arm is 22 at the dampener. You can file the notch in the arm (cover the opening to keep shavings out) to increase the "total" available. Need a high quality mini flat file or you'll be filing forever and you can epoxy strips of feeler gauge on either side of the can opening to limit the arms' travel into the can to reduce the "total". alot of trial and error but for a max mileage machine it's worth it. I'd suggest in order: set initial with vac gauge method then total (slot length +initial) for example 35 is a tried and true SB total (which is unrelated/not the can total) by welding/filing the slots then springs & the first (3) adjustments with can hose plugged then plug in & adj the vac can (slope tip in/can total), total first then slope
Re: Vacuum advance [Re: 62maxwgn] #1794760
04/02/15 05:09 PM
04/02/15 05:09 PM
Morristown Tn.
Morristown Tn.
I don't have one, that's why I was asking if those are available on the open market. I'll take that one that you have. Ha
Re: Vacuum advance [Re: 71birdJ68] #1794761
04/02/15 07:32 PM
04/02/15 07:32 PM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
I looked and looked for one for 383.
I finally bought another distributor to tinker with and to get the vacuum advance canister, but that one didn't work either, so I have given up on vacuum advance. I had to dial it way back or car would surge anyway, when it was working.
68 Roadrunner. 383 4-spd. Beat up.
Re: Vacuum advance [Re: Mebsuta] #1794762
04/02/15 08:57 PM
04/02/15 08:57 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
Rockauto has them.
With a quick search I looked up a 1973 dodge polara with a 440
Vc188- 8"hg @15 degree advance
4v104
vc187-10.5"hg @9 degree advance
Not all cars are listed as having them available, so I search other cars.
By the way I have an old dizzy machine to test and re-curve. Pm me if your wanting a dizzy set up.
Re: Vacuum advance [Re: 71birdJ68] #1794763
04/02/15 09:41 PM
04/02/15 09:41 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Crane used to make them.
Re: Vacuum advance [Re: Mebsuta] #1794764
04/02/15 10:21 PM
04/02/15 10:21 PM
You might be too lean and or too much adv from the can but I'd more suspect lean or too much total (initial+slots). I'd confirm that that total is 36-38 which is a tried and true amt for BB's & if you've bumped up your initial you might be way past that. And turning the allen wrench CCW 2 turns at a time & then maybe more & see if the surging goes away. you will be able to get the vac adv to work for you.
Re: Vacuum advance [Re: convx4] #1794765
04/03/15 01:14 AM
04/03/15 01:14 AM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
VC187 did not fit Chrysler single point distributor for 1968 383 for me. The arm is a little different.
Re: Vacuum advance [Re: 71birdJ68] #1794766
04/03/15 02:19 AM
04/03/15 02:19 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
19 73 would be a electronic dist .
vac adv will not fit / work on points dist !
Re: Vacuum advance [Re: 71birdJ68] #1798455
04/08/15 01:15 PM
04/08/15 01:15 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
I forgot about the arm being different. Early points units will fit an electronic dizzy but not the other way around.
Re: Vacuum advance [Re: convx4] #1799344
04/09/15 01:02 PM
04/09/15 01:02 PM
worst case, mod the arm so it will fit (assuming you cant find a point can)
