Drilling small drain holes in exhaust? #179450
12/31/08 09:39 AM
12/31/08 09:39 AM
West Coast, USA
jbc426 Offline OP
jbc426  Offline OP
West Coast, USA
If a guy drilled a few well-placed, very-small drain holes through the lowest spots of the exhaust system, would you hear them over the normal rumble and tumble of the car's engine etc, and would it help the longevity of the exhaust system?
Re: Drilling small drain holes in exhaust? [Re: jbc426] #179451
12/31/08 09:50 AM
12/31/08 09:50 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
No idea but my 99 crown vic has holes in the mufflers and you should see the water roll out of them at start up. At 1st I thought I needed new mufflers when a buddy told me, no that's supposed to happen. I would think if you drilled them after the mufflers you'd be ok.
Re: Drilling small drain holes in exhaust? [Re: jbc426] #179452
12/31/08 10:30 AM
12/31/08 10:30 AM
Richmond, VA
VT_Dart Offline
VT_Dart  Offline
Richmond, VA
I've seen many people do it on exhausts (including a lot of shops). Most of the time I see them pop a hole right in the lowest spot of the muffler. It has never made any noticeable sounding exhaust leak either.
Darrah Heath
Re: Drilling small drain holes in exhaust? [Re: VT_Dart] #179453
12/31/08 12:23 PM
12/31/08 12:23 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
This was done by the factory I believe.
Re: Drilling small drain holes in exhaust? [Re: AdamR] #179454
12/31/08 12:25 PM
12/31/08 12:25 PM
charlotte,nc
pyp1000 Offline
pyp1000  Offline
charlotte,nc
I think the tree huggers made the manufacturers get rid of the muffler weep hole due to environmental concerns. Its obviously much better for the environment if any condensation is blown out the rear of the pipes instead of just dripped upon the ground
Re: Drilling small drain holes in exhaust? [Re: jbc426] #179455
12/31/08 01:06 PM
12/31/08 01:06 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I've done it and could not hear any difference in the exhaust note.
Re: Drilling small drain holes in exhaust? [Re: Lefty] #179456
12/31/08 01:13 PM
12/31/08 01:13 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Friend of mine drilled some into the exhaust collector on the headers of a chevy he had. Said it was an old trick from Cali to get a car to pass emmissions.
It did get his car to pass. Seems to suck fresh air in.
Re: Drilling small drain holes in exhaust? [Re: NTOLERANCE] #179457
12/31/08 05:33 PM
12/31/08 05:33 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
My 02 Ram has a drip hole in the muffler from the factory.
Re: Drilling small drain holes in exhaust? [Re: earlybee] #179458
12/31/08 05:58 PM
12/31/08 05:58 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
My stock 340 tail pipes have them as well as the stock chrome tips and the stock mufflers. They were there to help eliminate some of the rusting issues. As many pointed out, the stock MOPARs still use them for the same reason. My Cuda leaves six wet spots when it idles in the cold. :)
Re: Drilling small drain holes in exhaust? [Re: Tom Hand] #179459
12/31/08 06:17 PM
12/31/08 06:17 PM
MO
cdp Offline
cdp  Offline
MO
My 71 GTX has weep holes in the mufflers and in the tail pipes right after bend back over the axles and come strait out.
I don't recall the tips having them, by my 69.5 RR has its original tips and the weep holes are in them.
Its part of a factory design to eliminat condensation and increase exhaust life.
Re: Drilling small drain holes in exhaust? [Re: jbc426] #179460
01/01/09 12:16 PM
01/01/09 12:16 PM
West Coast, USA
jbc426 Offline OP
jbc426  Offline OP
West Coast, USA
Thanks for all the great information. Now I gotta get under the car with a drill.
Re: Drilling small drain holes in exhaust? [Re: jbc426] #179461
01/01/09 12:28 PM
01/01/09 12:28 PM
AndyF Offline
AndyF  Offline
You have one gallon of water come out the exhaust for every gallon of gas that you burn so the water has to go somewhere. The weep holes are a great idea if you just do a lot of city driving. On the freeway the exhaust gets hot and most of the water goes out as a vapor but in town it stays a liquid.
Re: Drilling small drain holes in exhaust? [Re: jbc426] #179462
01/01/09 12:39 PM
01/01/09 12:39 PM
(1)no (2) yes, me too I've seen water just about gush out of a tailpipe, couldn't believe the amount.
Re: Drilling small drain holes in exhaust? [Re: RapidRobert] #179463
01/01/09 12:56 PM
01/01/09 12:56 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I worked at an "Exhaust Pros" shop from 95 to 01. Putting weep holes in the back of mufflers was common practice. It helps the most on vehicles that have the muffler at the back of the car. In those situations the muffler rarely gets hot enough for the water to burn off.
On a regular parts store muffler, you don't have to get out a drill. We just used an "al" and punched the hole. If you are using a stronger muffler like a Flowmaster, the case is too thick and you have to use a drill.
Re: Drilling small drain holes in exhaust? [Re: burdar] #179464
01/01/09 03:46 PM
01/01/09 03:46 PM
West Coast, USA
jbc426 Offline OP
jbc426  Offline OP
West Coast, USA
Any ideas on what size to use? Too small and it will plug, to big and it will be....well, too big.
Re: Drilling small drain holes in exhaust? [Re: jbc426] #179465
01/01/09 05:14 PM
01/01/09 05:14 PM
I beleive E'berg recommended an 1/8th".
Re: Drilling small drain holes in exhaust? #179466
01/02/09 01:29 PM
01/02/09 01:29 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
my 87 Diplomat had them stock, never heard any extra noise on the stock system, doubt you'd heard it with a louder than stock muffler.
Don't be the exception.
Re: Drilling small drain holes in exhaust? [Re: jbc426] #179467
01/02/09 01:42 PM
01/02/09 01:42 PM
If you start to experience headaches nausea or lightheadedness you may have went too far. I'd go with an 1/8" not only in the muff but every low bend in the system.
Re: Drilling small drain holes in exhaust? [Re: jbc426] #179468
01/03/09 02:42 PM
01/03/09 02:42 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
Factory 69/340 swinger exhaust tip, 1/8 hole. Mike
Re: Drilling small drain holes in exhaust? [Re: mkdart] #179469
01/03/09 05:35 PM
01/03/09 05:35 PM
West Coast, USA
jbc426 Offline OP
jbc426  Offline OP
West Coast, USA
Cool, thanks!
