Drilling small drain holes in exhaust?
#179450
12/31/08 09:39 AM
12/31/08 09:39 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
If a guy drilled a few well-placed, very-small drain holes through the lowest spots of the exhaust system, would you hear them over the normal rumble and tumble of the car's engine etc, and would it help the longevity of the exhaust system?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: Drilling small drain holes in exhaust?
[Re: jbc426]
#179452
12/31/08 10:30 AM
12/31/08 10:30 AM
Posts: 2,936 Richmond, VA
VT_Dart
Richmond, VA
I've seen many people do it on exhausts (including a lot of shops). Most of the time I see them pop a hole right in the lowest spot of the muffler. It has never made any noticeable sounding exhaust leak either.
Darrah Heath
[Re: Lefty]
#179456
12/31/08 01:13 PM
12/31/08 01:13 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Friend of mine drilled some into the exhaust collector on the headers of a chevy he had. Said it was an old trick from Cali to get a car to pass emmissions. It did get his car to pass. Seems to suck fresh air in.
[Re: jbc426]
#179460
01/01/09 12:16 PM
01/01/09 12:16 PM
jbc426
West Coast, USA
Thanks for all the great information. Now I gotta get under the car with a drill.
[Re: burdar]
#179464
01/01/09 03:46 PM
01/01/09 03:46 PM
jbc426
West Coast, USA
Any ideas on what size to use? Too small and it will plug, to big and it will be....well, too big.
[Re: jbc426]
#179465
01/01/09 05:14 PM
01/01/09 05:14 PM
I beleive E'berg recommended an 1/8th".
#179466
01/02/09 01:29 PM
01/02/09 01:29 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
my 87 Diplomat had them stock, never heard any extra noise on the stock system, doubt you'd heard it with a louder than stock muffler.
