Dome light trouble shooting.... #1794408
04/01/15 06:50 PM
04/01/15 06:50 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
70 Dart any ideas? Any help would be greatly appreciated.
Moparlee
Re: Dome light trouble shooting.... [Re: Robbins] #1794409
04/01/15 06:51 PM
04/01/15 06:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Would help to know what it was or wasn't doing. Comes on with the door open Yes or no. Comes on with the dash light switch turned all the over? Have you checked the bulb. Have you checked for power at he bulb? Have you checked for a ground?
Re: Dome light trouble shooting.... [Re: stumpy] #1794410
04/01/15 07:24 PM
04/01/15 07:24 PM
beedees Offline
beedees  Offline
Dome lights switch to ground.
Re: Dome light trouble shooting.... [Re: Robbins] #1794411
04/01/15 10:46 PM
04/01/15 10:46 PM
power comes from the fuse panel out to the dome light in a pink wire (think hot pink) then the yellow wire coming out from the fixture T's twice and can be grounded either by either (front) door switchs or the headlight switch when you turn it all the way CW. (1) check the fuse (2) see if the pink wire is hot at the dome light fixture (3) see if the yellow wire has continuity back to the HL switch/dr door (it T's from there sideways in the dash over to the pass door). (4) make sure the door switches are grounding. Grab your VOM. pull apart connectors are a good place to lose continuity.
Re: Dome light trouble shooting.... [Re: RapidRobert] #1794412
04/01/15 11:09 PM
04/01/15 11:09 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Make sure it has the correct bulb.I cant believe how many people put single contact bulbs in when it takes the dual contact.i went crazy with the first one I did because the guy put in the wrong bulb.Rocky
Chrysler Firepower
Re: Dome light trouble shooting.... [Re: therocks] #1794413
04/04/15 01:09 AM
04/04/15 01:09 AM
Florida, US
72ls5fla Offline
72ls5fla  Offline
Florida, US
Believe the dome light wires plug into the trunk harness
Come together by the deck lid hinge on dvr side
Make sure it did not come apart.
Got me a NEW Project
1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior.
Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
