340 / 318 Crank question
#1794102
04/01/15 09:48 AM
04/01/15 09:48 AM
Posts: 20 Ontario
Budsworth
Ontario
I recently picked up a 69 340 with a "Noise" in the bottom end, When I tore it down I found this.. (See Image) Looks like a Castcrank in an early block. I have a "Steel Crank" from a 68 318 that has been ground .010/.010 would this be a good replacement for a mild street application.
Re: 340 / 318 Crank question
[Re: Budsworth]
#1794103
04/01/15 09:51 AM
04/01/15 09:51 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Sure.. just check the balance on it EDIT What you have now is externally balanced with the conv and the front balancer so you need to get a internally balanced balancer and knock the weight off the conv but I would still have it balanced
[Re: MR_P_BODY]
#1794104
04/01/15 10:55 AM
04/01/15 10:55 AM
Posts: 20 Ontario
Budsworth
Ontario
What do I need to know and what is involved in rebalancing this rotating assembly. I have New in the box Damper from Pro Systems, as well I will be ordering a new vert for the 3.23:1 gears I plan on running.
[Re: Budsworth]
#1794105
04/01/15 11:14 AM
04/01/15 11:14 AM
MR_P_BODY
You just want to have it zero balanced(internally balanced)... so it would be just a normal 68 340 balance job.. you would take the parts into the company thats doing the balance, pistons,rods, rings, bearings, crank and the balancer.. let them zero all the rods and pistons then figure the bob weight and correct the crank... when you get your conv you would order a 68 340 style conv with zero balance(like all the older 340 were)
[Re: dogdays]
#1794108
04/01/15 02:37 PM
04/01/15 02:37 PM
Posts: 2,005 Apollo, PA.
B1MAXX
Apollo, PA.
1ST thing I thought too..... Balance job would be a mess with the heavier 340/360 rods. Lots of Mallory..$$
[Re: dogdays]
#1794110
04/01/15 03:38 PM
04/01/15 03:38 PM
MR_P_BODY
I don't agree. It's a forged crank. Cast cranks have sharp edges and squarish counterweights. This crank has rounded "kidney shaped" counterweights that to my eye look forged.
R.
A cast crank is usually smoother.. but I always look at the separation line on the counter weight.. a wide line is forged and a thin line is cast... I dont see any line on that pic... but he said cast..
[Re: moper]
#1794111
04/01/15 03:41 PM
04/01/15 03:41 PM
Posts: 43,255 Bend,OR USA
Cab_Burge
I know several drag racers of SB motors that looked for the forged steel crankshafts out of the 318-3 truck motors to use in there short stock stroke 340 motors, they had to have thin steel plates welded onto the counter weights to get them to balance correctly. This was before Mallory metal was used in balancing IHTHs
Re: 340 / 318 Crank question *DELETED*
[Re: dogdays]
#1794119
04/05/15 09:57 AM
04/05/15 09:57 AM
Posts: 20 Ontario
Budsworth
Ontario
Post deleted by Budsworth
[Re: Budsworth]
#1794120
04/05/15 10:08 AM
04/05/15 10:08 AM
Posts: 20 Ontario
Budsworth
Ontario
Ask and you shall receive, as they say. Thank your for your input Dogdays. In the original post I stated "Looks like" well I have learned quite a bit in regards to Mopar factory small block crankshafts this week. Yesterday I went searching on the local classifieds, I found and purchased a standard/standard Forged Steel crankshaft out of 1967 273. I checked the rear register with a digital caliper and it has the larger 1.8 vs the smaller 1.5 now I have a second option. And for $80.00 bucks.. That's cheaper than a slug of Mallory.
