Milodon oil line routing? #179386
12/31/08 02:37 AM
12/31/08 02:37 AM
Someplace you aren't
SomeCarGuy Offline OP
I'm getting ready to fire up my 383 that I put the first external oiling system on that I have ever had.
I got to noticing that the 12AN line is dangerously close to the header. I have my doubts on how long it will last. Maybe not long at all.
How are you all routing your lines?
Could I use reducers somehow and make it live? That would cut flow some for sure but this system is really overkill by far for what I have currently. It is really a trial run before I put a more serious engine in.
I want my fair share
Re: Milodon oil line routing? [Re: SomeCarGuy] #179387
12/31/08 02:57 AM
12/31/08 02:57 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Dual line on the Hemi. I try to route them as close to the block as I can, keeps them away from the headers.
Dont have any pictures of either of the B1's handy.
Re: Milodon oil line routing? [Re: Al_Alguire] #179388
12/31/08 03:07 AM
12/31/08 03:07 AM
I guess I should add that this is a 69 RR, 383 with 1 7/8s hooker headers, single line milodon system.
I had a time getting the line to fit at all.
Re: Milodon oil line routing? [Re: SomeCarGuy] #179389
12/31/08 03:22 AM
12/31/08 03:22 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
don't even think about reducers. you might as well be using the stock internal oiling system if you do.
Re: Milodon oil line routing? [Re: rebel] #179390
12/31/08 11:39 AM
12/31/08 11:39 AM
How do I get this to fit?
I might as well have stock on there if the header burns the line.
Re: Milodon oil line routing? [Re: SomeCarGuy] #179391
12/31/08 11:48 AM
12/31/08 11:48 AM
UK
602heavy Offline
602heavy  Offline
UK
Looks like you'll have to reconfigure those lines off the pickup , i see the logic regards drainback , but you'll have to reroute them down lower.
Re: Milodon oil line routing? [Re: SomeCarGuy] #179392
12/31/08 02:26 PM
12/31/08 02:26 PM
Do you know if the flex line is the Teflon or Neoppreme inner lining? If Neopreme switch to a teflon lined hose and go for it, the teflon hoses will live strap to the header let alone close to it. The bad thing on the teflon hoses are they are a lot stiffer than the neopmeme hoses are and a there harder to fit around tight corners
Re: Milodon oil line routing? [Re: Cab_Burge] #179393
12/31/08 05:11 PM
12/31/08 05:11 PM
White House,TN
stroked470 Offline
stroked470  Offline
White House,TN
I used the Milodon single line static setup on my Hemi in my 70 Cuda. I couldn't get the line to work with my Hooker headers I was using. We have a shop here in town that makes pressure hoses for all kind of applications. I had them make me a longer lines with high pressure fittings and run the line towards the from and around the K member. It was alot higher then the oil pan and worked fine I think it cost around $40 for the new line. It was also a stainless braided line just not as flexible as the one that came with the kit.
Re: Milodon oil line routing? [Re: SomeCarGuy] #179394
12/31/08 05:32 PM
12/31/08 05:32 PM
AndyF Offline
AndyF  Offline
You just have to work around the obstacles. I usually run a motor plate so that makes the hose routing a little easier. Here is an example.
Re: Milodon oil line routing? [Re: AndyF] #179395
01/01/09 10:10 PM
01/01/09 10:10 PM
I noticed that the dual line setups use the rear port off the pump cover.
Can I use that for the single line setup? I think it will clear by a mile if I can come straight off that port.
I'm not sure why I have it ran to the side port as I put that on over a year ago and had to stop the project. I have a feeling that there is a reason why that one was used.
Re: Milodon oil line routing? [Re: SomeCarGuy] #179396
01/01/09 10:16 PM
01/01/09 10:16 PM
I have used both the back and the fitting on the top for single lines systems depending on the motors used in different chassis, B-RB in A bodys and B-RB and 426 Hemi in B and E bodys Both work fine, I like to use the rear one if I can due to not making the oil go around a 90 degree turn in the cover to get into the pump
Re: Milodon oil line routing? [Re: Cab_Burge] #179397
01/01/09 11:46 PM
01/01/09 11:46 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
heres mine TTI headers in a A body:
BB, TT5,Procharged 3300lb Street Car 4.79/154
Post deleted by Defbob [Re: bigtimeauto] #179398
01/02/09 12:01 AM
01/02/09 12:01 AM
Re: Milodon oil line routing? #179399
01/02/09 01:01 AM
01/02/09 01:01 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Milodon oil line routing? [Re: SomeCarGuy] #179400
01/02/09 09:24 AM
01/02/09 09:24 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
what brand headers are you using?
the right fittings will get the line away from the headers.
Re: Milodon oil line routing? [Re: jughed] #179401
01/02/09 07:04 PM
01/02/09 07:04 PM
Hookers. They were on a RB. Not sure if they were tall deck specific. Had to work one pipe heavily to clear the mini starter.
I'm curious about the teflon in the line comment. I need to remember what brand it was and look it up. remember the fittings being na red package.
Looks like the rear port is OK to use, that should work OK. Just need a new fitting to make it happen.
Re: Milodon oil line routing? [Re: SomeCarGuy] #179402
01/02/09 07:15 PM
01/02/09 07:15 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I notice i half the setups pictured the lines come out of the pump & imediately turn downward, while thats great for clearance I've always heard running a short upward loop in the suction lines helped prevent the external line system lose it's prime...
Re: Milodon oil line routing? [Re: 1_WILD_RT] #179403
01/03/09 12:26 PM
01/03/09 12:26 PM
Las Vegas
afxcoronet Offline
afxcoronet  Offline
Las Vegas
I don't have any pictures of mine, but I actually had to plumb into the passenger side of the pan, (Moroso b-Body pan w/ deep center sump), and looped it around the the front of sump in pan, it is just under the k-member for about 2 inches, no issues so far, been like that for 2 seasons. good Luck, Curtis
Taking over the World one win light at a time.
Re: Milodon oil line routing? [Re: SomeCarGuy] #179404
01/03/09 03:34 PM
01/03/09 03:34 PM
Hookers. I'm curious about the teflon in the line comment. I need to remember what brand it was and look it up. remember the fittings being na red package.
Most of the aftermarket companys that sell the AN fittings and lines sell the fittings for the teflon lines and the lines, the fittings are different so don't plan on using any fittings you have for neopreme on the tefleon line ends You will need the #12 O ring male fittings for the pump, straight, 45 degree or 90 degree. I'm not sure if any of the 45 or 90 degrees come in a regular fitting that do not need the locknut to make the O ring seal, those fittings are not teflon specific Either way order what you need. You can order the teflon end fittings in straight, 45 or 90 degree ends also Good luck, post a picture when your done
Re: Milodon oil line routing? [Re: Cab_Burge] #179405
01/03/09 07:09 PM
01/03/09 07:09 PM
Thanks.
I got sick so I missed my chance to get much done. My window of oportunity is closing for the moment. Hopefully can at least do some more figuring on the routing and get the stuff ordered for the next good chance.
Looking at the Smmit catalog, I would say that I used Aeroquip stuff. It doesn't say it is teflon so I'm guessing that it isn't as that would seem to be a selling point.
