Milodon oil line routing?
#179386
12/31/08 02:37 AM
12/31/08 02:37 AM
Posts: 10,215 Someplace you aren't
SomeCarGuy
I'm getting ready to fire up my 383 that I put the first external oiling system on that I have ever had.
I got to noticing that the 12AN line is dangerously close to the header. I have my doubts on how long it will last. Maybe not long at all.
How are you all routing your lines? Could I use reducers somehow and make it live? That would cut flow some for sure but this system is really overkill by far for what I have currently. It is really a trial run before I put a more serious engine in.
I want my fair share
Re: Milodon oil line routing?
[Re: SomeCarGuy]
#179387
12/31/08 02:57 AM
12/31/08 02:57 AM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
Dual line on the Hemi. I try to route them as close to the block as I can, keeps them away from the headers. Dont have any pictures of either of the B1's handy.
Post deleted by Defbob
[Re: bigtimeauto]
#179398
01/02/09 12:01 AM
01/02/09 12:01 AM
[Re: 1_WILD_RT]
#179403
01/03/09 12:26 PM
01/03/09 12:26 PM
Posts: 1,151 Las Vegas
afxcoronet
Las Vegas
I don't have any pictures of mine, but I actually had to plumb into the passenger side of the pan, (Moroso b-Body pan w/ deep center sump), and looped it around the the front of sump in pan, it is just under the k-member for about 2 inches, no issues so far, been like that for 2 seasons. good Luck, Curtis
Taking over the World one win light at a time.
[Re: SomeCarGuy]
#179404
01/03/09 03:34 PM
01/03/09 03:34 PM
Posts: 43,204 Bend,OR USA
Cab_Burge
Hookers. I'm curious about the teflon in the line comment. I need to remember what brand it was and look it up. remember the fittings being na red package.
Most of the aftermarket companys that sell the AN fittings and lines sell the fittings for the teflon lines and the lines, the fittings are different so don't plan on using any fittings you have for neopreme on the tefleon line ends You will need the #12 O ring male fittings for the pump, straight, 45 degree or 90 degree. I'm not sure if any of the 45 or 90 degrees come in a regular fitting that do not need the locknut to make the O ring seal, those fittings are not teflon specific Either way order what you need. You can order the teflon end fittings in straight, 45 or 90 degree ends also Good luck, post a picture when your done
