Can you identify this hurst shifter? #179335
12/30/08 11:52 PM
12/30/08 11:52 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
I was told this came out of a dart but it doesn't look right to me. Anyone ever seen this shifter before?
Thanks,
Steve
Re: Can you identify this hurst shifter? [Re: srunge55] #179336
12/30/08 11:53 PM
12/30/08 11:53 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
Another picture
Re: Can you identify this hurst shifter? [Re: srunge55] #179337
12/30/08 11:54 PM
12/30/08 11:54 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
one more
Re: Can you identify this hurst shifter? [Re: srunge55] #179338
12/31/08 12:23 AM
12/31/08 12:23 AM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
Not sure but looks like a three speed shifter
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
Re: Can you identify this hurst shifter? [Re: 69superbee383] #179339
12/31/08 12:25 AM
12/31/08 12:25 AM
MO
cdp Offline
cdp  Offline
MO
All 3 speeds I've ever saw were bolted on top like an inland.
Looks like an a-body bench seat shifter.
Like 67-72 or so.
Re: Can you identify this hurst shifter? [Re: srunge55] #179340
12/31/08 12:10 PM
12/31/08 12:10 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Not enough of a forward bend in the handle, IMO, for it to be an A body shifter, and those shift rod adjusters don't look like OE Mopar either; none that I've ever seen. Here's an OE Hurst O/D A body shifter - note the adjusters on the rods...
Re: Can you identify this hurst shifter? [Re: srunge55] #179341
12/31/08 12:15 PM
12/31/08 12:15 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
There wil be a 4 digit number stamped into the side of one of the shifter rod fingers near where the rod goes through it, what number is it?
Re: Can you identify this hurst shifter? [Re: Sixpak] #179342
12/31/08 12:17 PM
12/31/08 12:17 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Looks like an old Hurst 3 speed Mystery Shifter.An aftermarket replcement for the 3 on the tree.
Re: Can you identify this hurst shifter? [Re: Sixpak] #179343
12/31/08 03:54 PM
12/31/08 03:54 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
I can't find any numbers on the rod lever fingers. Does that mean is some type of aftermarket shifter? There is a serial number on the shifter mechanism - 0070332A.
I don't think its a three speed because it has 3 levers. I thought 2 speed only had 2.
Thanks for the help,
Steve
Re: Can you identify this hurst shifter? [Re: srunge55] #179344
12/31/08 07:05 PM
12/31/08 07:05 PM
Irwin, PA
62BT409 Offline
62BT409  Offline
Irwin, PA
I do not rememeber a 3-speed with 3 rods connected....usually only 2 rods...1st and reverse and the 2nd rod...2nd to 3rd. Just my $.02 worth
Re: Can you identify this hurst shifter? [Re: 62BT409] #179345
12/31/08 08:48 PM
12/31/08 08:48 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
Its a GM shifter.
I was hoping it was for a 69 dart.
Here is one just like it on ebay:
http://cgi.ebay.com/ebaymotors/FACTORY-H...sQ5fAccessories
thanks for the help all.
Steve
Re: Can you identify this hurst shifter? [Re: srunge55] #179346
01/01/09 12:22 AM
01/01/09 12:22 AM
MO
cdp Offline
cdp  Offline
MO
atleast it has some value. You might come out ahead of you clean it up and put it on ebay.
