1970 gtx disk brakes #1792891
03/31/15 09:41 PM
03/31/15 09:41 PM
Waterloo, Wi
joedee Offline OP
joedee  Offline OP
Waterloo, Wi
Hi,
Does anyone make a disk brake conversion kit that uses the original spindles. I have never done is before and want the job to be easy.
Joe
Re: 1970 gtx disk brakes [Re: joedee] #1792892
03/31/15 09:54 PM
03/31/15 09:54 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I know from experience Wilwood does and I suspect most others do as well.
Re: 1970 gtx disk brakes [Re: Lefty] #1792893
03/31/15 11:20 PM
03/31/15 11:20 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I purchased a Wilwood kit for my 70 Charger with original 11" front drums. This kit uses the original spindles.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 1970 gtx disk brakes [Re: joedee] #1792894
03/31/15 11:26 PM
03/31/15 11:26 PM
AndyF Offline
AndyF  Offline
The original disc brake spindles? Probably not. There are kits for OEM drum brake spindles but they are mostly lightweight drag race kits.
Best bet is to swap on the late model disc brakes from a Mopar. Then you'll still have parts store replacements.
Re: 1970 gtx disk brakes [Re: joedee] #1792895
04/01/15 01:27 AM
04/01/15 01:27 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Joe
Go get a set-up off of an 81 up Diplomat. It doesn't get any easier... Mine were from an 87 Gran Fury...direct bolt on to a 70 Satellite.
...FAFO...
Re: 1970 gtx disk brakes [Re: skicker] #1792896
04/01/15 01:39 AM
04/01/15 01:39 AM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
I used the spindles off a disk brake '73 up A body and caliper adapters off a St Regis, calipers from NAPA for E body, 11.75" mopar cop car disks from NAPA, one of the last sets of semi metallic brake pads from Mopar. All MOPAR and correct geometry. Get the info HERE.
I’m listening.
Re: 1970 gtx disk brakes [Re: Big Bad Bee] #1792897
04/01/15 12:41 PM
04/01/15 12:41 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Easy, get the spindle bearing spacers from Dr.Diff for the '70-2 B/E disc spindles. Then buy a pair of 11.75" rotors from the parts store and a pair of caliper adapter brackets from any number of sources.
