Re: Slick circumference measurement ?......
[Re: D-50]
#1792026
03/30/15 10:13 PM
03/30/15 10:13 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I use a seamstress tape measure to measure mine.
[Re: MR_P_BODY]
#1792029
03/30/15 10:34 PM
03/30/15 10:34 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Well all I had to measure them was a regular tape measure and it showed the left was a 1/4 in smaller than the right. I know that was probably not very accurate and showed the opposite of what could be the problem so I just swapped sides and I will just see what happens. I will also carry my Drag Radials and swap them out if it is still going to the right. I am running caltrac bars and they say if it is going to the right to put more preload on the right. I tried that yesterday and it did not help at all, maybe worse.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#1792030
03/30/15 10:39 PM
03/30/15 10:39 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Heck I've checked them with a string.
[Re: pittsburghracer]
#1792031
03/31/15 12:40 AM
03/31/15 12:40 AM
Posts: 5,107 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Slight air pressure differences can make them the same diameter but may also affect how well they hook.
...FAFO...
[Re: ek3]
#1792033
03/31/15 08:28 AM
03/31/15 08:28 AM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
There is no way that I would put 70 to 80 pounds in a slick!!! I wouldn't go past 35 pounds, slicks are pretty thin, and not designed for that much pressure... Circle track tires are a lot stiffer than a slick...
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: D-50]
#1792036
03/31/15 03:09 PM
03/31/15 03:09 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Put a small blob of enamel paint on the center of the tread and roll the tire...measure between the paint dots.
