Slick circumference measurement ?...... #1792025
03/30/15 10:11 PM
03/30/15 10:11 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I usually run 315/60 M/T Drag Radials but I went to T&T at a marginal hooking track. I have a set of old 29.5/10.5W slicks on a 14 in. rim and I put them on my D50 to try. It hooked every pass but It would pull the front wheels about 3 ft. off the ground and head straight to the right every time.Most of the time I had to let completely off the throttle. It has never done that with the Drag Radials. I was wondering if one of the tires is bigger around than the other one or what do you think what the problem could be. What is the best way to measure the circumference?
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Slick circumference measurement ?...... [Re: D-50] #1792026
03/30/15 10:13 PM
03/30/15 10:13 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I use a seamstress tape measure to measure mine.
Re: Slick circumference measurement ?...... [Re: D-50] #1792027
03/30/15 10:19 PM
03/30/15 10:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Next time swap sides with the slicks and see if the
problem moves with them
Re: Slick circumference measurement ?...... [Re: MR_P_BODY] #1792028
03/30/15 10:26 PM
03/30/15 10:26 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Slick circumference measurement ?...... [Re: MR_P_BODY] #1792029
03/30/15 10:34 PM
03/30/15 10:34 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Well all I had to measure them was a regular tape measure and it showed the left was a 1/4 in smaller than the right. I know that was probably not very accurate and showed the opposite of what could be the problem so I just swapped sides and I will just see what happens. I will also carry my Drag Radials and swap them out if it is still going to the right.
I am running caltrac bars and they say if it is going to the right to put more preload on the right. I tried that yesterday and it did not help at all, maybe worse.
Re: Slick circumference measurement ?...... [Re: D-50] #1792030
03/30/15 10:39 PM
03/30/15 10:39 PM
PA.
"Little"John
"Little"John
PA.
Heck I've checked them with a string.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Slick circumference measurement ?...... [Re: pittsburghracer] #1792031
03/31/15 12:40 AM
03/31/15 12:40 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Slight air pressure differences can make them the same diameter but may also affect how well they hook.
...FAFO...
Re: Slick circumference measurement ?...... [Re: D-50] #1792032
03/31/15 12:57 AM
03/31/15 12:57 AM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
buy your self an[8'x 1/8 "] tape to measure the tires . circle track tricks.... inflate the smaller tire to 70-80 lbs and let it stretch in the sun. it will be larger than you need for a little while but will stabilize to a smaller size. you can measure the tire with the extra air press. and learn what amount of extra time and pressures it takes for your type of tire. this works best with bias ply tires, however ,it will work to some degree on all tires. also , you can add air to one tire and subtract from the other to adjust the steering from the rear tires
Re: Slick circumference measurement ?...... [Re: ek3] #1792033
03/31/15 08:28 AM
03/31/15 08:28 AM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
There is no way that I would put 70 to 80 pounds in a slick!!! I wouldn't go past 35 pounds, slicks are pretty thin, and not designed for that much pressure... Circle track tires are a lot stiffer than a slick...
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Slick circumference measurement ?...... [Re: Dartsport540] #1792034
03/31/15 10:46 AM
03/31/15 10:46 AM
hustlin hoosier Offline
At 40 lbs it will grow 1/2 of an inch over night an 1/2 wider. we do this all of the time.
Re: Slick circumference measurement ?...... [Re: hustlin hoosier] #1792035
03/31/15 01:13 PM
03/31/15 01:13 PM
Sth.IL
dare_dude Offline
dare_dude  Offline
Sth.IL
Re: Slick circumference measurement ?...... [Re: D-50] #1792036
03/31/15 03:09 PM
03/31/15 03:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Put a small blob of enamel paint on the center of the tread and roll the tire...measure between the paint dots.
