Frame Ties Done #1791450
03/29/15 09:02 PM
03/29/15 09:02 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Finally finished the ties on the 68`.
Knocked out the baffles in the rear frames so I can run the battery cable and the fuel line inside the frame and connectors.
Should have the underside in paint by next weekend
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Frame Ties Done [Re: 6bblFLASH] #1791451
03/29/15 09:04 PM
03/29/15 09:04 PM
N.E. Ohio
N.E. Ohio
#2
Re: Frame Ties Done [Re: 6bblFLASH] #1791452
03/29/15 09:05 PM
03/29/15 09:05 PM
N.E. Ohio
N.E. Ohio
#3
Re: Frame Ties Done [Re: 6bblFLASH] #1791453
03/29/15 09:06 PM
03/29/15 09:06 PM
N.E. Ohio
N.E. Ohio
#4
Re: Frame Ties Done [Re: 6bblFLASH] #1791454
03/29/15 09:11 PM
03/29/15 09:11 PM
N.E. Ohio
N.E. Ohio
Re: Frame Ties Done [Re: 6bblFLASH] #1791455
03/29/15 10:21 PM
03/29/15 10:21 PM
Maryland
K
Keepat Offline
Keepat  Offline
K
Maryland
Nice job on the subframe connectors, I like how you past through the crossmember!
Pat
Re: Frame Ties Done [Re: Keepat] #1791456
03/30/15 11:55 AM
03/30/15 11:55 AM
Powell, Ohio ( Originally Pitt...
1970Dart3406 Offline
Nice!
Re: Frame Ties Done [Re: 6bblFLASH] #1791457
03/30/15 03:36 PM
03/30/15 03:36 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Looks really well thought out.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Frame Ties Done [Re: OhioMopar] #1791458
03/30/15 09:28 PM
03/30/15 09:28 PM
N.E. Ohio
N.E. Ohio
I`m pretty happy with it.
They are square with the rockers height wise so they should`nt be to noticable.
Even put a tapered relief it the right one for the parking brake cable to clear.
I really enjoy cutting and modifying perfectly good parts........
Re: Frame Ties Done [Re: 6bblFLASH] #1791459
03/31/15 12:18 AM
03/31/15 12:18 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I like how you did these. Especially at the rear.
Whats the specs of the tubing ? size and wall thickness ?
I Assume this is boxed tubing .
I have a 68 Charger we are going to add frame ties and this looks like it might fit the bill very well
Re: Frame Ties Done [Re: gtx6970] #1791460
03/31/15 09:28 AM
03/31/15 09:28 AM
N.E. Ohio
N.E. Ohio
Yes box tubing.
1-1/2 x 2-1/2" x .125 wall.
To get them parallel with the rocker height its flush with the bottom at the front and 3/4" from the bottom at the rear.
The flange at the joint of the floor near the rear will need to be flattened some. but once you get it fitted it all is kinda self explanatory.
Re: Frame Ties Done [Re: 6bblFLASH] #1944899
11/04/15 10:10 AM
11/04/15 10:10 AM
N.E. Ohio
N.E. Ohio
I didn't want cut the floors at all,so I spent some time staring at it and this is the results.
I did something similar on my brothers 63` A-body,but those have different angles.
