Frame Ties Done
#1791450
03/29/15 09:02 PM
03/29/15 09:02 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Finally finished the ties on the 68`. Knocked out the baffles in the rear frames so I can run the battery cable and the fuel line inside the frame and connectors. Should have the underside in paint by next weekend
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Frame Ties Done
[Re: OhioMopar]
#1791458
03/30/15 09:28 PM
03/30/15 09:28 PM
6bblFLASH
N.E. Ohio
Thanks I`m pretty happy with it. They are square with the rockers height wise so they should`nt be to noticable. Even put a tapered relief it the right one for the parking brake cable to clear. I really enjoy cutting and modifying perfectly good parts........
Re: Frame Ties Done
[Re: gtx6970]
#1791460
03/31/15 09:28 AM
03/31/15 09:28 AM
6bblFLASH
N.E. Ohio
Yes box tubing. 1-1/2 x 2-1/2" x .125 wall.
To get them parallel with the rocker height its flush with the bottom at the front and 3/4" from the bottom at the rear. The flange at the joint of the floor near the rear will need to be flattened some. but once you get it fitted it all is kinda self explanatory.
Re: Frame Ties Done
[Re: 6bblFLASH]
#1944899
11/04/15 10:10 AM
11/04/15 10:10 AM
6bblFLASH
N.E. Ohio
I didn't want cut the floors at all,so I spent some time staring at it and this is the results. I did something similar on my brothers 63` A-body,but those have different angles.
