Input Shaft Bearing Press Fit? #1790622
03/28/15 09:43 PM
03/28/15 09:43 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Rebuilding an 833, new input bearing (307) pretty much slid right on. Is this going to be an issue?
Re: Input Shaft Bearing Press Fit? [Re: GTX MATT] #1790623
03/28/15 09:50 PM
03/28/15 09:50 PM
Cab_Burge Online work
Cab_Burge  Online Work
It should not slide on and off Did the old one slide off? If so it is probally the shaft causing the issue, if it didn't slide off maybe it is the new bearing inner race being to big on the I.D.
Re: Input Shaft Bearing Press Fit? [Re: Cab_Burge] #1790624
03/28/15 10:24 PM
03/28/15 10:24 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Its a new input shaft and a new bearing
Re: Input Shaft Bearing Press Fit? [Re: GTX MATT] #1790625
03/29/15 12:22 AM
03/29/15 12:22 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
What shaft is it? I mean who made it? I have heard some of the aftermarket gear sets aren't top quality machine work
Gus
64 Plymouth Savoy
Dana 60
Re: Input Shaft Bearing Press Fit? [Re: fourgearsavoy] #1790626
03/29/15 12:28 AM
03/29/15 12:28 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Last input shaft bearing I installed slid on, but I heated it up first.
Don't be the exception.
Re: Input Shaft Bearing Press Fit? [Re: Supercuda] #1790627
03/29/15 12:49 AM
03/29/15 12:49 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
From Brewers, I want to try to get a hold of Wayne, was planning to put this together tomorrow. Anyone know his username on here? I know its 64Dodge or something but couldn't find it.
Re: Input Shaft Bearing Press Fit? [Re: GTX MATT] #1790628
03/29/15 12:54 AM
03/29/15 12:54 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
use a center punch and put a few divots in the shaft. now press the bearing on.
Re: Input Shaft Bearing Press Fit? [Re: Stanton] #1790629
03/29/15 05:22 AM
03/29/15 05:22 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Input Shaft Bearing Press Fit? [Re: John_Kunkel] #1790630
03/29/15 05:46 AM
03/29/15 05:46 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
My new 9310 input shaft was the same way. I consulted Jamie Passon and he said this is normal. I used loctite sleeve retainer and let it set up over night.
Re: Input Shaft Bearing Press Fit? [Re: Jeremiah] #1790631
03/29/15 05:00 PM
03/29/15 05:00 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
GTX Matt, It should be a press fit but using the correct Loctite is acceptable. I rarely need to do this assembling a trans but it does happen.
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Input Shaft Bearing Press Fit? [Re: 64dodge572] #1790632
03/30/15 01:25 PM
03/30/15 01:25 PM
dogdays Offline
dogdays  Offline
No way would I mark up the OD of the input shaft. Each divot is a stress riser and can lead to failure. The outermost parts of the shaft are the most highly loaded.
The Loctite would be my preferred method, and I do this stuff for a living.
R.
Re: Input Shaft Bearing Press Fit? [Re: GTX MATT] #1790633
03/30/15 02:23 PM
03/30/15 02:23 PM
Being that the engineers designed those to be a press fit that is what I would want
Re: Input Shaft Bearing Press Fit? [Re: GTX MATT] #1790634
03/30/15 03:51 PM
03/30/15 03:51 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I've rebuilt more 833's than I want to admit. I've never had ONE, that the input bearing slid on the input shaft. All had to be forced on, one way or another. Of course I haven't done as many as Brewers has, but still......
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Input Shaft Bearing Press Fit? [Re: 68LAR] #1790635
03/31/15 11:10 PM
03/31/15 11:10 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
As long as the centerline is held and the retaining ring takes up any endplay, it really doesn't matter.
" The last official act of any goverment, is to loot the treasury" George Washington
Re: Input Shaft Bearing Press Fit? [Re: zzyzxpat] #1790636
04/01/15 01:57 AM
04/01/15 01:57 AM
If the bearing races slides onto the input shaft how can you hold the center to the center .0002 or more lateral, out of round, movement is enough to wear out the pilot bushing in the cranksahft Don't ask me how I know about that
Re: Input Shaft Bearing Press Fit? [Re: Jeremiah] #1790637
04/01/15 02:25 AM
04/01/15 02:25 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's only somewhat normal on the late OD trans ... in my experience only on the rear bearing ... I've never just slid an input bearing on a NON OD trans input shaft.
Re: Input Shaft Bearing Press Fit? [Re: JohnRR] #1790638
04/01/15 02:37 AM
04/01/15 02:37 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
So you guys are saying my transmission is going to self destruct? I'd like to hear something more than speculation on this. If you haven't worked through this problem please don't muddy the waters.
Re: Input Shaft Bearing Press Fit? [Re: Jeremiah] #1790639
04/01/15 02:52 AM
04/01/15 02:52 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Is yours working?
I put mine together, used the sleeve retainer. Any lateral play was unmeasurable with the tools that I have and not apparent to the naked eye. The sleeve retainer held well.
I could tap the input bearing off the old input shaft pretty easily with a small ball peen hammer against the retaining clip, so I felt more better about it. This thing gets abused so I guess we'll find out. I'd think the worst that can happen is it wont hold, the input will spin in the bearing, generate heat, and weld itself to the bearing, in which case it will work as designed anyway?
Are they pressed for any other reason than to keep them centered? Reduce heat that can be caused by the input spinning in the bearing?
Re: Input Shaft Bearing Press Fit? [Re: GTX MATT] #1790640
04/01/15 03:26 AM
04/01/15 03:26 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
My last aftermarket input shaft didn't have the clearance issue and the bearing pressed on like a stock unit does. The latest 9310 input shaft has a .000 fit from my measurements so in theory the sleeve retainer will be just fine. Once it's all put together there is really nowhere for the input shaft to go if you think about it. On the other hand not indicating the bell housing will cause problems. To answer your question I am not sure at this point. That said I am going to run it and beat it like it owes me money. I can't really go back because we have out 833 gear sets face plated with Liberty stuff. Let us know how yours works. We are getting into floating on the pond and convertible season around here so my interest in cars wanes seasonally. We might have the red 4-speed Charger running this summer but I have pretty much given up hope lol. Good luck and happy shifting!
Re: Input Shaft Bearing Press Fit? [Re: Jeremiah] #1790641
04/01/15 11:29 AM
04/01/15 11:29 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'm never said it's going to self destruct.
I said that the bearing should not just slip on. If you put something in there to lock the shaft to the inner race then you SHOULD be good to go.
