Input Shaft Bearing Press Fit?
#1790622
03/28/15 09:43 PM
03/28/15 09:43 PM
Posts: 5,163 CT
GTX MATT
CT
Rebuilding an 833, new input bearing (307) pretty much slid right on. Is this going to be an issue?
Re: Input Shaft Bearing Press Fit?
[Re: Cab_Burge]
#1790624
03/28/15 10:24 PM
03/28/15 10:24 PM
Posts: 5,163 CT
GTX MATT
CT
Its a new input shaft and a new bearing
[Re: fourgearsavoy]
#1790626
03/29/15 12:28 AM
03/29/15 12:28 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Last input shaft bearing I installed slid on, but I heated it up first.
[Re: Supercuda]
#1790627
03/29/15 12:49 AM
03/29/15 12:49 AM
Posts: 5,163 CT
GTX MATT
CT
From Brewers, I want to try to get a hold of Wayne, was planning to put this together tomorrow. Anyone know his username on here? I know its 64Dodge or something but couldn't find it.
[Re: Jeremiah]
#1790631
03/29/15 05:00 PM
03/29/15 05:00 PM
Posts: 4,285 Ohio
64dodge572
Ohio
My new 9310 input shaft was the same way. I consulted Jamie Passon and he said this is normal. I used loctite sleeve retainer and let it set up over night.
GTX Matt, It should be a press fit but using the correct Loctite is acceptable. I rarely need to do this assembling a trans but it does happen.
Dan
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: Jeremiah]
#1790637
04/01/15 02:25 AM
04/01/15 02:25 AM
Posts: 75,021 U.S.S.A.
JohnRR
U.S.S.A.
It's only somewhat normal on the late OD trans ... in my experience only on the rear bearing ... I've never just slid an input bearing on a NON OD trans input shaft.
[Re: Jeremiah]
#1790641
04/01/15 11:29 AM
04/01/15 11:29 AM
JohnRR
U.S.S.A.
So you guys are saying my transmission is going to self destruct? I'd like to hear something more than speculation on this. If you haven't worked through this problem please don't muddy the waters.
I'm never said it's going to self destruct.
I said that the bearing should not just slip on. If you put something in there to lock the shaft to the inner race then you SHOULD be good to go.
