Speedo gear O ring #1790538
03/28/15 08:46 PM
03/28/15 08:46 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Which way does the o ring/gasket face in the pinion housing if you are looking from the outside of the transmission looking in? Does the snap ring go in after it to retain it? Looks like there is no groove for the snap ring??
Re: Speedo gear O ring [Re: GTX MATT] #1790539
03/29/15 03:11 AM
03/29/15 03:11 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
The "flat" side of seal faces out and it seats on a slight step in the speedo housing IIRC. The little wire ring rests up against it then and does not fit in a groove.
Re: Speedo gear O ring [Re: GTX MATT] #1790540
03/29/15 05:13 AM
03/29/15 05:13 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Close up pic.
Re: Speedo gear O ring [Re: John_Kunkel] #1790541
03/29/15 02:56 PM
03/29/15 02:56 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Alright perfect, thanks guys!
