i'm having an issue with my trans, seemed to be shifting fine at first for like 200 miles... after having the carb and intake off shifted fine again but after some miles now from a stop in drive sometimes it barely moves (seems like slipping) and eventually shifts to 2nd but then into third shifts fine. although if i manually start in first it accelerates fine, manually shifts into second find but then when shift into drive it acts like it goes into neutral for a second then into drive?? also if cruising in drive and i kick it into passing gear it'll downshift fine but sometimes also seem like shifting into neutral or slipping??
i've been doing some google searches and maybe the linkage needs adjustment which makes sense because i'm not sure i understood how to adjust it correctly plus it came off a different car and the trans is an ebay buy.
any help would be much appreciated
