19 spline 727 big block trans weird slipping #1790336
03/28/15 04:23 PM
03/28/15 04:23 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
i'm having an issue with my trans, seemed to be shifting fine at first for like 200 miles... after having the carb and intake off shifted fine again but after some miles now from a stop in drive sometimes it barely moves (seems like slipping) and eventually shifts to 2nd but then into third shifts fine. although if i manually start in first it accelerates fine, manually shifts into second find but then when shift into drive it acts like it goes into neutral for a second then into drive?? also if cruising in drive and i kick it into passing gear it'll downshift fine but sometimes also seem like shifting into neutral or slipping??
i've been doing some google searches and maybe the linkage needs adjustment which makes sense because i'm not sure i understood how to adjust it correctly plus it came off a different car and the trans is an ebay buy.
any help would be much appreciated
1962 Chrysler 300 convertible 383/727
1970 Dodge A108 Boogie Van 318/727
Re: 19 spline 727 big block trans weird slipping [Re: maxi333] #1790337
03/28/15 04:54 PM
03/28/15 04:54 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Can you post-a-pic of the carb and trans end of the linkage ?
Re: 19 spline 727 big block trans weird slipping [Re: maxi333] #1790338
03/28/15 06:02 PM
03/28/15 06:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Barely moves forward in Drive but moves forward OK in manual first is a classic symptom of a failed roller clutch (sprag).
Re: 19 spline 727 big block trans weird slipping [Re: dOc !] #1790339
03/29/15 05:29 PM
03/29/15 05:29 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
just saw your post, i'll get some pics today. the kickdown was about an inch away from the carb throttle shaft wish i would have checked before driving it. i readjusted according to the chilton's and the 727 tf book. took it for another test drive and similar results, although i must have adjusted something wrong because it wouldn't shift in my console correctly... reverse was down toward neutral and i'd have to shift into 2nd then up to drive before it went into drive. it drove better, the barely moving was gone but still seemed to slip a little. i quickly came back and once i went under the car to investigate my adjustments the trans was really hot to the touch. if i remove the pan will there be anything to let me know for sure the sprag is toast, like excess metal?
thanks for the replies
Re: 19 spline 727 big block trans weird slipping [Re: maxi333] #1790340
03/29/15 10:36 PM
03/29/15 10:36 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
well after another adjustment it still acts like it's slipping here's some pics of the linkage but with the heat that is coming of this trans after only a few miles i can't imagine it's only a linkage adjustment
Re: 19 spline 727 big block trans weird slipping [Re: maxi333] #1790341
03/29/15 10:37 PM
03/29/15 10:37 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
another
Re: 19 spline 727 big block trans weird slipping [Re: maxi333] #1790342
03/29/15 10:39 PM
03/29/15 10:39 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
so i have a rebuilt bb 727 sitting in the shop, it's my pops and he has let it sit for about 5 years... think i could just throw the trans in without issue?
