Re: cragar wheels help
[Re: joedee]
#1789622
03/27/15 09:54 PM
03/27/15 09:54 PM
Posts: 12,114 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Backspace is the measurement from the inside wheel lip to it's hub.
What did the wheels come off of? 8" wheels on the front might rub the fender when turned with some sizes of tires.
The rears are easy to measure for since they don't turn, but the fronts are a bit tougher. Any chance you can take one and try it on the front of your car?
Master, again and still
[Re: DaveRS23]
#1789624
03/27/15 10:30 PM
03/27/15 10:30 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Unless someone here has experience with that particular combination on a similar car, I would test mount one on the front and on the rear of your car. Turn the front fully left to right on the ground and check for tight spots or points of contact.
Only way to know for sure.
[Re: joedee]
#1789625
03/27/15 10:45 PM
03/27/15 10:45 PM
Posts: 623 Zombieland
Car Nut
Zombieland
Hi, They came off of '76 Camaro . Mounted on 245-60-15 tires.
Is the bolt pattern the same? You'll need 5x4.5 bolt pattern.
[Re: Car Nut]
#1789626
03/27/15 11:16 PM
03/27/15 11:16 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Alot of Cragar SS's were uni-lug.
And I would think closer to 4 1/2" back spacing would be needed?
[Re: OzHemi]
#1789627
03/27/15 11:37 PM
03/27/15 11:37 PM
Car Nut
Zombieland
I don't think the Cragar SS on my 70 Challenger were, but that was 24 yrs ago.
[Re: OzHemi]
#1789629
03/28/15 12:42 AM
03/28/15 12:42 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Cragars i bought in 71 were unilug.They had a piece that webt in the back to be either 4 1/2 or 4 3/4. Rocky
Chrysler Firepower
[Re: joedee]
#1789631
03/28/15 10:07 AM
03/28/15 10:07 AM
Posts: 5,623 Detroit area
6PAX
Detroit area
Found some wheels and need to know what I really need for my 1970 GTX. I do not understand all the back space stuff. The ones I am looking at say Cragar SS wheels with 3 5/8 backspace. Will these work on the GTX? They are 15 x 8 wheels.
I have 15x8 Cragar SS wheels with 4 1/4" BS on the rear of my 70 GTX with 275-60 tires. I can't say if the same tire on a wheel with 3 5/8 BS would fit but I wouldn't think a narrower tire like a 245-60 or 255-60 would be a problem.
[Re: 6PAX]
#1789632
03/28/15 11:05 AM
03/28/15 11:05 AM
Posts: 5,163 CT
GTX MATT
CT
In my opinion, no. If they will you will have to run a skinny tire, and unless they're very cheap not worth the hassle they are going to cause you.
[Re: GTX MATT]
#1789633
03/28/15 12:10 PM
03/28/15 12:10 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
People run 10" wheels, 295 tires with 5" of backspacing. So that leaves 6" on the outside. An 8" wheel with 3-5/8 would be 5-3/8 on the outside... So I don't see the problem.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1789634
03/28/15 12:40 PM
03/28/15 12:40 PM
Posts: 5,105 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Mine are 17x9.5 with 5 1/2" bs outside to outside of lip measures +/- 10 3/8". The 15x8 with 3 5/8" bs outside to outside should measure about 9". If you do the math they are going to stick out about 3/8" further than mine do. If your car sets low they will try to rub on the outside. If it sets high you may be able to make them work. Before you buy them verify that they are unilug...if not they won't fit in the first place. Here's the kicker that a lot of guys don't realize...the wheel width is measured from the inside lip where the tire bead sets to the other lip where the tire sets...not at the outside. If you measured these and they are 8" on the outside they will work since it is only really a 7" wide wheel.
...FAFO...
[Re: joedee]
#1789637
03/29/15 05:56 PM
03/29/15 05:56 PM
Car Nut
Zombieland
Not sure what wheel size will work with all this info. I did find another set of 15 x 7 rally wheels but here is the spec. 5 x 4 inch bolt pattern with 4.25 inch backspace. Will this bolt up to my gtx and fit correctly? What tire size will work? I would like larger tire in the rear.
Joe
I know my Charger has a 5 x 4.5 inch big bolt pattern, so I believe the GTX is the same. Those are the small bolt pattern.
So, they're not unilug?
