cragar wheels help #1789621
03/27/15 09:00 PM
03/27/15 09:00 PM
Waterloo, Wi
joedee Offline OP
joedee  Offline OP
Waterloo, Wi
Hi,
Found some wheels and need to know what I really need for my 1970 GTX. I do not understand all the back space stuff. The ones I am looking at say Cragar SS wheels with 3 5/8 backspace. Will these work on the GTX? They are 15 x 8 wheels.
Thank you,
Joe
Re: cragar wheels help [Re: joedee] #1789622
03/27/15 09:54 PM
03/27/15 09:54 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Backspace is the measurement from the inside wheel lip to it's hub.
What did the wheels come off of? 8" wheels on the front might rub the fender when turned with some sizes of tires.
The rears are easy to measure for since they don't turn, but the fronts are a bit tougher. Any chance you can take one and try it on the front of your car?
Master, again and still
Re: cragar wheels help [Re: DaveRS23] #1789623
03/27/15 10:11 PM
03/27/15 10:11 PM
Waterloo, Wi
joedee Offline OP
joedee  Offline OP
Waterloo, Wi
Hi,
They came off of '76 Camaro . Mounted on 245-60-15 tires.
Re: cragar wheels help [Re: DaveRS23] #1789624
03/27/15 10:30 PM
03/27/15 10:30 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Unless someone here has experience with that particular combination on a similar car, I would test mount one on the front and on the rear of your car. Turn the front fully left to right on the ground and check for tight spots or points of contact.
Only way to know for sure.
Re: cragar wheels help [Re: joedee] #1789625
03/27/15 10:45 PM
03/27/15 10:45 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Hi,
Is the bolt pattern the same? You'll need 5x4.5 bolt pattern.
Re: cragar wheels help [Re: Car Nut] #1789626
03/27/15 11:16 PM
03/27/15 11:16 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Hi,
Alot of Cragar SS's were uni-lug.
And I would think closer to 4 1/2" back spacing would be needed?
Re: cragar wheels help [Re: OzHemi] #1789627
03/27/15 11:37 PM
03/27/15 11:37 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Hi,
I don't think the Cragar SS on my 70 Challenger were, but that was 24 yrs ago.
Re: cragar wheels help [Re: Car Nut] #1789628
03/27/15 11:45 PM
03/27/15 11:45 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Alot...but not all...
I deal with Carlise/Carlstar who make Cragar....see them "fresh off the line" in big piles all the time.
Re: cragar wheels help [Re: OzHemi] #1789629
03/28/15 12:42 AM
03/28/15 12:42 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Cragars i bought in 71 were unilug.They had a piece that webt in the back to be either 4 1/2 or 4 3/4. Rocky
Chrysler Firepower
Re: cragar wheels help [Re: therocks] #1789630
03/28/15 01:41 AM
03/28/15 01:41 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I have some of all 3 4.5, unilug and 4.75. The come in many configurations but as stated A LOT are unilug, easier for tire stores to stock back in the day, easier for guys to move them from car to car, worse to be truly balanced cause you never get them exactly centered.
Careful, your character's showing!
Re: cragar wheels help [Re: joedee] #1789631
03/28/15 10:07 AM
03/28/15 10:07 AM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
I have 15x8 Cragar SS wheels with 4 1/4" BS on the rear of my 70 GTX with 275-60 tires. I can't say if the same tire on a wheel with 3 5/8 BS would fit but I wouldn't think a narrower tire like a 245-60 or 255-60 would be a problem.
Re: cragar wheels help [Re: 6PAX] #1789632
03/28/15 11:05 AM
03/28/15 11:05 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
In my opinion, no. If they will you will have to run a skinny tire, and unless they're very cheap not worth the hassle they are going to cause you.
Re: cragar wheels help [Re: GTX MATT] #1789633
03/28/15 12:10 PM
03/28/15 12:10 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
People run 10" wheels, 295 tires with 5" of backspacing. So that leaves 6" on the outside. An 8" wheel with 3-5/8 would be 5-3/8 on the outside... So I don't see the problem.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: cragar wheels help [Re: Silver70] #1789634
03/28/15 12:40 PM
03/28/15 12:40 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Mine are 17x9.5 with 5 1/2" bs outside to outside of lip measures +/- 10 3/8".
The 15x8 with 3 5/8" bs outside to outside should measure about 9".
If you do the math they are going to stick out about 3/8" further than mine do. If your car sets low they will try to rub on the outside. If it sets high you may be able to make them work.
Before you buy them verify that they are unilug...if not they won't fit in the first place.
Here's the kicker that a lot of guys don't realize...the wheel width is measured from the inside lip where the tire bead sets to the other lip where the tire sets...not at the outside. If you measured these and they are 8" on the outside they will work since it is only really a 7" wide wheel.
...FAFO...
Re: cragar wheels help [Re: skicker] #1789635
03/29/15 05:50 PM
03/29/15 05:50 PM
Waterloo, Wi
joedee Offline OP
joedee  Offline OP
Waterloo, Wi
Not sure what wheel size will work with all this info. I did find another set of 15 x 7 rally wheels but here is the spec. 5 x 4 inch bolt pattern with 4.25 inch backspace. Will this bolt up to my gtx and fit correctly? What tire size will work? I would like larger tire in the rear.
Joe
Re: cragar wheels help [Re: joedee] #1789636
03/29/15 05:53 PM
03/29/15 05:53 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
No, 5 on 4" bolt pattern will not fit a B body... (that would be early-ish A body)
An 8" wheel with the right back spacing and a 275/60-15 is a pretty nice combo on the back.
Re: cragar wheels help [Re: joedee] #1789637
03/29/15 05:56 PM
03/29/15 05:56 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Joe
I know my Charger has a 5 x 4.5 inch big bolt pattern, so I believe the GTX is the same. Those are the small bolt pattern.
So, they're not unilug?
Re: cragar wheels help [Re: Car Nut] #1789638
03/29/15 06:15 PM
03/29/15 06:15 PM
Waterloo, Wi
joedee Offline OP
joedee  Offline OP
Waterloo, Wi
So, only 5 x 4.5 inch big bolt pattern will work on a 1970 gtx? The back space is? Just trying to limit the ones I am looking at. I am thinking 15 x 7 for all 4 or 15 x 7 for front and 15 x 8 for the backs.
Joe
Re: cragar wheels help [Re: joedee] #1789639
03/29/15 06:25 PM
03/29/15 06:25 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Correct, your GTX is 5 on 4 1/2 bolt pattern. And yes, 15 x 7 up front and 15 x 8 out back will be a good combo as well. (235/60 and 275/60 seem to be a no-brainer combo for "most" B bodies..)
Re: cragar wheels help [Re: OzHemi] #1789640
03/29/15 06:28 PM
03/29/15 06:28 PM
Waterloo, Wi
joedee Offline OP
joedee  Offline OP
Waterloo, Wi
what it the correct back space? is that the 4 1/2 of the 5 x 4 1/2?
Joe
