Blower Motor #178946
12/30/08 04:02 PM
12/30/08 04:02 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Refurbishing my non A/C heater box on my E body. I wanted to test the motor, so I did +2+ and -to- on the battery. Nothing. So I tried it with the new motor. Also nothing. What's up?
Grandma always said I had "hands of gold"!
Re: Blower Motor [Re: CHRGR69] #178947
12/30/08 05:59 PM
12/30/08 05:59 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
It should spin even if you have the polarity reversed?
Re: Blower Motor [Re: 69Cuda340S] #178948
12/30/08 06:09 PM
12/30/08 06:09 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Correct! I did that too with both motors. Nothing! Does the casing have to be grounded?
Re: Blower Motor [Re: CHRGR69] #178949
12/30/08 06:57 PM
12/30/08 06:57 PM
None
71rm23 Offline
71rm23  Offline
None
I was affraid that mine wouldn't work when I rebuilt my heater box. I tested it on a battery. Pos to pos, neg to ground. Viola, it worked
Re: Blower Motor [Re: 71rm23] #178950
12/30/08 09:23 PM
12/30/08 09:23 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
The blower motor in my car has one power and one ground wire. I was just testing it today because I was diagnosing a squeaking noise in the motor. If I connect 12 volts to the ground and positive wires of the motor it spins. The motor case itself was not grounded. The motor would spin if I switch polarity too.
