Questions on gaskets for E58 360 Oil Pan
#1789457
03/27/15 05:13 PM
03/27/15 05:13 PM
Posts: 15,902 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Mechanic is replacing the Oil Pan Gasket (under warranty) on my '80 Aspen A38/E58. I have a Milodon one piece o/p gasket to give him. I also will need a rear main seal, right? Excuse my ignorance on the subject. If I do, please direct me to the best type/brand so I won't be going thru this again. He is doing all labor under warranty because it's leaked since he replaced it before.
Thanks.
Facts are stubborn things.
Re: Questions on gaskets for E58 360 Oil Pan
[Re: larrymopar360]
#1789460
03/27/15 05:35 PM
03/27/15 05:35 PM
Posts: 15,487 Florida
scratchnfotraction
Hi Larry look at the new oil seal from superformance get them at Hughes or other moparts sponsers. I just tried a few of the gaskets out and really like them so far.
[Re: larrymopar360]
#1789461
03/27/15 05:42 PM
03/27/15 05:42 PM
RapidRobert
If the Milodon 1pc gasket has the (2) side flat gaskets and (2) end black neoprene seals that fit into the oil pan half moon cutouts all connected & I am assuming that is what it is then that is it for an oil pan gasket (+ cement). If he was to replace the black neoprene rear main seals (2 halves) he'd pull the #5 main cap & one half goes in it then drop the crank a hair to R&R the other half that is up in the block groove.
[Re: larrymopar360]
#1798779
04/08/15 07:54 PM
04/08/15 07:54 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Well this is quite an old thread, but I've just gotten busy and had to put the old Mopes on hold, which I hate. But just wanted to upadate that I just ordered the Superformance gasket set as recommended. Hopefully the end of next week I can install the pan and have the old girl back on the road! Thanks.
