dipstick location #1789034
03/26/15 09:24 PM
03/26/15 09:24 PM
ky, usa
littlejohn44 Offline OP
ky, usa
I have a rear sump pan and the dipstick hole is in the front, how do i make it work? the pan is baffled to keep from flying out of the sump.
Re: dipstick location [Re: littlejohn44] #1789035
03/26/15 10:00 PM
03/26/15 10:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The stick in the front will work.. the oil will seek
its level... the baffles are not oil tight
Re: dipstick location [Re: MR_P_BODY] #1789036
03/26/15 10:09 PM
03/26/15 10:09 PM
ky, usa
ky, usa
So i should fill the pan past its sump up to the front of the pan? It flattens out for about an inch deep until it hits the sump. so should i fill the pan up to about 1/2 from the top?
Re: dipstick location [Re: littlejohn44] #1789037
03/26/15 10:30 PM
03/26/15 10:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is the stick the stock one for that engine.. just fill
to the normal height
Re: dipstick location [Re: littlejohn44] #1789038
03/26/15 11:08 PM
03/26/15 11:08 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Sounds like you have same problem as me. The front of my pan next to the dipstick is so shallow that the stick hits the bottom of the pan. No way do I want the oil level that high. Still thinking about what I'm going to do. Site glass tube, relocate dipstick tube to the pan.
Doug
Re: dipstick location [Re: dvw] #1789039
03/26/15 11:14 PM
03/26/15 11:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug
Is the stick hitting the pan or the baffle.. if its
hitting the baffle just drill a hole in it for the
stick to go down through
EDIT
If the OP has a pan like Doug is talking about I would
just weld in a port on the pan... is it steel or
alum either way... weld a bung on the side for the
stick to mount in.. just put it to clear everything
(inside and out)
Re: dipstick location [Re: MR_P_BODY] #1789040
03/26/15 11:32 PM
03/26/15 11:32 PM
ky, usa
ky, usa
no its a lokar , so i have to cut it to fit.
Re: dipstick location [Re: littlejohn44] #1789041
03/27/15 12:00 AM
03/27/15 12:00 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A couple of questions.. are you trying to find out
what the pan holds and is the pan like Doug said about
the front at the stick... is the pan on the engine
and in the car or is it on the engine stand
Re: dipstick location [Re: MR_P_BODY] #1789042
03/27/15 12:20 PM
03/27/15 12:20 PM
ky, usa
ky, usa
the pan is like doug said its to shallow in the front and i would have to have 8 quarts in a 7 quart pan just to register. I didnt think about the bung idea but it might be my only option. The motor is still on the stand.
Re: dipstick location [Re: littlejohn44] #1789043
03/27/15 12:57 PM
03/27/15 12:57 PM
Alberta
rustbuckett68 Offline
Alberta
Rear sump van pans have a channel built in to place the stick to the deep part of the pan. Not sure if trucks are similar, but van pans come off easy. If you could find one, you could replicate the channel and calibrate the stick. The stick is quite long.
Re: dipstick location [Re: littlejohn44] #1789044
03/27/15 11:52 PM
03/27/15 11:52 PM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Not the same pan but might give you an idea. Lokar dipstick also.
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: dipstick location [Re: 68cuda440] #1789045
03/28/15 03:13 AM
03/28/15 03:13 AM
ky, usa
ky, usa
is that a screw in ? did you weld a bung in the pan?
Re: dipstick location [Re: littlejohn44] #1789046
03/28/15 11:39 AM
03/28/15 11:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Even a O-ring style would work in that application
