727 dip stick lenght #1788672
03/26/15 11:31 AM
03/26/15 11:31 AM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
hello,
can anyone measure fill mark on dipstick from pan rail (above/below) inside 727 tranny with pan off?
need to make custom stick on tube chassis car,
thanks
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: 727 dip stick lenght [Re: 440lebaron] #1788673
03/26/15 06:29 PM
03/26/15 06:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The FULL mark on the dipstick is 1/4" above the flat area on the case where the dipstick tube is inserted.
Re: 727 dip stick lenght [Re: John_Kunkel] #1788674
03/26/15 06:42 PM
03/26/15 06:42 PM
westerly, ri. usa
westerly, ri. usa
thanks
that should work
Re: 727 dip stick lenght [Re: 440lebaron] #1788675
03/26/15 11:10 PM
03/26/15 11:10 PM
South Lyon MI
sleddinfool Offline
sleddinfool  Offline
South Lyon MI
You can also contact Dan at Masta performance.com. All he does is build trick dipsticks and tubes. Have had them on both my cars.If you look close you can see both on my engine/trans Kevin
71 gtx.....
Re: 727 dip stick lenght [Re: 440lebaron] #1788676
03/26/15 11:41 PM
03/26/15 11:41 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
Interesting question...What if you have a 8" converter. How accurate would the STOCK dipstick be??
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
