Repair or replace '71 Satellite door hinges? #1786694
03/23/15 04:29 PM
03/23/15 04:29 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Hi all,
Both driver and passenger side hinges on my '71 Satellite have issues. The passenger side is worse, as the retainer at the bottom of the vertical pin appears to be broken:
What is my best course of action here? Does anyone offer a rebuild kit for '71-74 B-body hinges? Or would it be better to replace them with new ones, such as those offered by Classic Industries?
http://www.classicindustries.com/product/mopar/parts/mm1895.html
As always, any suggestions would be appreciated. Thanks.
Roger
Re: Repair or replace '71 Satellite door hinges? [Re: Fab64] #1786695
03/23/15 04:46 PM
03/23/15 04:46 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
The ones on my '71 Charger, I disassembled and rebuilt myself with hardware store parts.
On my '74 Dodge Power Wagon I bought, degreased, repainted and installed a lightly Used hinge that was still in good condition.
A good quality rebuild Kit should be available. Year One or others sell rebuild components or complete hinges:
Year One Door hinges Link
Re: Repair or replace '71 Satellite door hinges? [Re: Fab64] #1786696
03/23/15 06:06 PM
03/23/15 06:06 PM
RSNOMO Online rolleyes
Moparts Torchbearer
RSNOMO  Online Rolleyes
Moparts Torchbearer
OEM number was superseded by a truck hinge...
Don't know if they're still available...
Unless you have to stay 'stock'...
Re: Repair or replace '71 Satellite door hinges? [Re: RSNOMO] #1786697
03/23/15 07:18 PM
03/23/15 07:18 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
No, this car has been heavily modified, so I'm not really concerned that they be stock. However, I'm thinking it might be better if I could rebuild these, since they're already body color. If I buy new ones, I'll have to get them painted = more hassle & cost. I know Resto Rick offers a nice hinge rebuild kit, but it's only for '66-70 B bodies. Does anyone offer a good kit for '71-74 hinges?
Re: Repair or replace '71 Satellite door hinges? [Re: Fab64] #1786698
03/23/15 08:09 PM
03/23/15 08:09 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Would these rebuilt one fit, YearOne is clearing them out for $125.00 to $150.00.
https://www.yearone.com/Product/chrysler-b-body/dhb7172 or
https://www.yearone.com/Product/1966-74-a-b-e-body/dhe7074
If they will work, use code SLAM5 to get 30% off.
Re: Repair or replace '71 Satellite door hinges? [Re: Fab64] #1786699
03/23/15 09:06 PM
03/23/15 09:06 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
If possible, it's usually better to rebuild stock originals, than to use Chinese stuff that may, or may not be as good.
Re: Repair or replace '71 Satellite door hinges? [Re: Car Nut] #1786700
03/23/15 09:08 PM
03/23/15 09:08 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
I just found this rebuild kit, for only $45:
Classic Industries 71-74 B-body door hinge rebuild kit
Has anyone tried this one, and how did it work out?
Re: Repair or replace '71 Satellite door hinges? [Re: Car Nut] #1786701
03/23/15 10:15 PM
03/23/15 10:15 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Thanks that code worked.
Re: Repair or replace '71 Satellite door hinges? [Re: Fab64] #1786702
03/23/15 11:53 PM
03/23/15 11:53 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Check with Resto Rick. I bought his kit with the right drill bit for my 69 Charger and it worked great.
Re: Repair or replace '71 Satellite door hinges? [Re: NITROUSN] #1786703
03/24/15 02:58 PM
03/24/15 02:58 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Drill em out, put a new pin in and done. Or if you don't like that, rock auto sells hinge pin kits for dirt cheap. Same thing, you drill your old pin holes open, pop the bushings in, drop the pins in and done.
Re: Repair or replace '71 Satellite door hinges? [Re: Fab64] #1786704
03/24/15 04:12 PM
03/24/15 04:12 PM
st.louis mo
satjoe Offline
satjoe  Offline
st.louis mo
I lookedat the picture, the only thing i see is wrong is the roll pin, or spring pin is broke at the bottom, probably due to rust. I think everything else looks fine. You can but a pin kit from NAPA for about $13-15. I just rebuilt my hinges, i made some parts and bought some. I have the correct length spring (roll) pins and American made springs if you're interested. I also have a couple of arms that hold the door open, and can make the roller that it rides on. Those parts are made of good quality steel. PM me if interested. Joe
Re: Repair or replace '71 Satellite door hinges? [Re: satjoe] #1786705
03/26/15 12:33 AM
03/26/15 12:33 AM
Central New York
bfury Offline
bfury  Offline
Central New York
AMD has new hinges for this car.
No Stock
Re: Repair or replace '71 Satellite door hinges? [Re: bfury] #1786706
03/26/15 09:56 PM
03/26/15 09:56 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Some of those don't fit correctly, be careful with AMD. Three years ago I bought a AMD set from YearOne that was junk. I just bought the clearance rebuilt set for my 69 Charger from YearOne with a 30% off sale code - SLAM5.
Re: Repair or replace '71 Satellite door hinges? [Re: Car Nut] #1786707
03/26/15 10:39 PM
03/26/15 10:39 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Another option is to use the later B Body Hinges with the "S" spring. P/Ns 3788022 and 023. I did this to my 73 cars. Not sure if they're available as repros. I bought mine from Ma Mopar when they were still available.
Common sense is a flower that does not grow in everybody's garden
Re: Repair or replace '71 Satellite door hinges? [Re: Ron_M] #1786708
03/27/15 02:33 PM
03/27/15 02:33 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
I appreciate all the suggestions, guys. A couple days ago, I removed the lower passenger side hinge, and confirmed that the roll pin holding the vertical roller in place had slipped out, thus allowing the roller to bind up. I compressed the spring, drove the pin back in, and it seems to be working for now. While I had it out, I realized that rebuilding all four hinges is a bit more work than I want to tackle. After the 30% discount, a set of four re-manufactured hinges at Year One is only $105 (thanks, Car Nut!!), so I just ordered a set. After I paint them, I'll swap them in and they should be good for another 40 years.
Thanks again.
Roger
Re: Repair or replace '71 Satellite door hinges? [Re: Fab64] #1786709
03/27/15 04:01 PM
03/27/15 04:01 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Re: Repair or replace '71 Satellite door hinges? [Re: Fab64] #1786710
03/27/15 05:23 PM
03/27/15 05:23 PM
Georgia
Steve Bryant Offline
Georgia
I bought a rebuilt set from YearOne a few weeks ago and they painted up nicely and bolted up perfectly.
The set they shipped looked like rebuilt originals to me.
Re: Repair or replace '71 Satellite door hinges? [Re: Fab64] #1786711
03/29/15 06:01 PM
03/29/15 06:01 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Is there a easy way of replacing the hinges on a painted car without removing the doors ? Or is removing the doors a must , and I would imagine pretty heavy . Can't remember the last time removing a door on a 71 B Body
My lower hinge , the spring is gone , stopper
71 Charger
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Repair or replace '71 Satellite door hinges? [Re: bfury] #1786712
03/29/15 09:53 PM
03/29/15 09:53 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i wouldn't waste my money on them just because of the cheap kind of metal they use.
the originals didn't last very long made with a real material
these doors are pretty heavy fully loaded.
i just cannot see the amd ones lasting very long unless
you rarely open your doors.
Re: Repair or replace '71 Satellite door hinges? [Re: flypaper] #1786713
03/29/15 10:57 PM
03/29/15 10:57 PM
Moparts Torchbearer
Moparts Torchbearer
Which is exactly why I went with 'truck' hinges...
They get lubed once a year...
They will outlive me...
