Disc brake conversion B/E body on an A body quest #1786342
03/23/15 12:56 AM
03/23/15 12:56 AM
Minnesota USA
Dart6pak Offline OP
Dart6pak  Offline OP
Minnesota USA
I pickup a new unused Classic performance 11" disc brake conversion from a guy who said they were bolted up to a 1972 Duster---the calipers hang behind the upper control arms and above the tie rod connection --will this work on my A body
Re: Disc brake conversion B/E body on an A body quest [Re: Dart6pak] #1786343
03/23/15 01:11 AM
03/23/15 01:11 AM
Missouri
MOBodyman Offline
MOBodyman  Offline
Missouri
Duster is a-body too, not sure I understand what you are asking....
Dallas
2012 Rallye Redline Challenger, 1st new car!
2010 Ram 1500 4wd HEMI-hauler
2014 Dodge Dart-gas saver
4 projects and a bunch of parts cars, losing interest since buying the Challenger lol
1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: Disc brake conversion B/E body on an A body quest [Re: MOBodyman] #1786344
03/23/15 01:17 AM
03/23/15 01:17 AM
Minnesota USA
Dart6pak Offline OP
Dart6pak  Offline OP
Minnesota USA
my question is --do A body calipers hang infront or behind the upper control arms---just because they were bolted up in a Duster does not necessarily mean they were right
Re: Disc brake conversion B/E body on an A body quest [Re: Dart6pak] #1786345
03/23/15 01:19 AM
03/23/15 01:19 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Depends on the year...Spindles can be swapped side to side, so it really doesn't matter, but there may be sway bar clearance issues in some cases when front hung.
Re: Disc brake conversion B/E body on an A body quest [Re: Jim_Lusk] #1786346
03/23/15 11:13 AM
03/23/15 11:13 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
73-76 calipers from the factory were in front. You can use them in the rear just fine. I'm not sure of the specifics of the kit you bought but typically you need to change the rubber brake hose when using them mounted to the rear. I think Dr. Diff recommends a 68 Camaro hose when mounting behind.
...FAFO...
Re: Disc brake conversion B/E body on an A body quest [Re: Dart6pak] #1786347
03/24/15 02:14 AM
03/24/15 02:14 AM
Missouri
MOBodyman Offline
MOBodyman  Offline
Missouri
Ok, I understand now
I see you have a couple of good answers too.
Dallas
