Banjo fitting leaks #1785676
03/22/15 02:22 PM
03/22/15 02:22 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
I have banjo fittings on all 4 of my GM calipers on my 33. Can't get 3 of them to seal. Leaks appear to be between the caliper circular serrated surface and the brass washers. Tried lots of washers to no avail. Any type of sealer I can use in that area? Thanks, John
Fastest 300
Re: Banjo fitting leaks [Re: Crizila] #1785677
03/22/15 03:03 PM
03/22/15 03:03 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Check the seal surface of the banjo for grooves. Try thicker copper washers. If it still seeps, try a little pipe dope.
Re: Banjo fitting leaks [Re: Crizila] #1785678
03/22/15 03:14 PM
03/22/15 03:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have had some issues with certain copper seal rings
but if I recall they were metric rings... I would
check the calipers with some fine sand paper to see
if its close to flat.. I have never tried any sealer
being that is basically a lube to tighten the fittings
and I wouldnt trust it to hold pressure.. it can be
up to 2000+ psi
Re: Banjo fitting leaks [Re: Crizila] #1785679
03/22/15 03:24 PM
03/22/15 03:24 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have banjo fittings on all 4 of my GM calipers on my 33. Can't get 3 of them to seal. Leaks appear to be between the caliper circular serrated surface and the brass washers. Tried lots of washers to no avail. Any type of sealer I can use in that area? Thanks, John [/quote}
There are different thickness washers. Sometimes the caliper hose hits part of the caliper if the washer is to thin and cocks the hose.
Doug
Re: Banjo fitting leaks [Re: dvw] #1785680
03/23/15 12:02 AM
03/23/15 12:02 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Lapped both sides of the banjo fittings with some 600 paper and I think that cured it. Thanks all.
Fastest 300
Re: Banjo fitting leaks [Re: Crizila] #1785681
03/23/15 04:45 PM
03/23/15 04:45 PM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
I have had some banjo fittings not seat correctly on some gm metric calipers on my dirt cars. you may have that issue just grind the offending area away.
Re: Banjo fitting leaks [Re: Crizila] #1785682
03/23/15 06:14 PM
03/23/15 06:14 PM
Martinsburg WV
mrm82 Offline
mrm82  Offline
Martinsburg WV
Just in case you still have the problems, I went through the same thing a couple weeks ago. I bought stat-o-seal washers off of jegs, they have a synthetic oring mechanically locked into the middle of the crush washer. Cured my leaks right up! They were 4 a piece though!!
Re: Banjo fitting leaks [Re: mrm82] #1785683
03/23/15 08:55 PM
03/23/15 08:55 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I have had replacement copper seals not want to seal and I believe they are to hard to allow a seal. Using the old ones seemed better than the new ones. You do not want any sealants or washers with seals made into them.
Re: Banjo fitting leaks [Re: NITROUSN] #1785684
03/24/15 02:24 AM
03/24/15 02:24 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Did you use a copper washer on both sides of the banjo?
