Re: AN to NPT adapter. Is this right?
[Re: titan]
#1785521
03/22/15 10:57 AM
03/22/15 10:57 AM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
you don't use tape but you need to use some Teflon paste. Joe
Without Data, you’re just another guy with an opinion.
[Re: rickseeman]
#1785523
03/22/15 11:15 AM
03/22/15 11:15 AM
Posts: 192 central Florida
titan
central Florida
Take the pump apart and tap it deeper so you can get more threads
yeah, that's what I'm leaning towards, think I would feel the most comfortable.
[Re: Jerry]
#1785525
03/22/15 12:22 PM
03/22/15 12:22 PM
sr4440
Central TEXAS!!!!
i just looked at the M60514 pump and it looks like it has a 3/8 inverted flare.
[Re: titan]
#1785527
03/22/15 12:50 PM
03/22/15 12:50 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You can be looking at 2 things that are out of spec.. the pump might be on the small side and the fitting on the large size.. I see it a lot... easiest thing is the run a tap in deeper into the pump(take it apart) EDIT the reason is the coating they put on the pump and the fittings... its done after the threads are cut
[Re: titan]
#1785530
03/22/15 01:28 PM
03/22/15 01:28 PM
MR_P_BODY
this is what it looks like with fitting as tight as i feel comfortable with.
Myself I dont like the fitting sticking out that far.. too easy to break them off... if you have your next fitting on it and bang into it, its likely to break off right at the pump
[Re: titan]
#1785532
03/22/15 03:27 PM
03/22/15 03:27 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Personally, after seeing that I too would run a tap, make sure it's a NPT Tap and go in so more threads are sent into the pump. Just don't go crazy with the tap.And remember to put a little grease on the tap so the shavings don't go into the pump but stick to the tap.
[Re: Sammy]
#1785534
03/22/15 08:24 PM
03/22/15 08:24 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I'd prefer taking the cover off over grease , but when tapping with a pipe tap , go maybe a turn at a time. They open up quickly , so it isn't going to take a whole lot to sink the fitting in where you want it.
[Re: titan]
#1785536
03/22/15 08:33 PM
03/22/15 08:33 PM
MR_P_BODY
tapped out the threads & ran the threads of the fittings over my wire wheel bench grinder. all is well. Thanks fella's.
